Old 07-16-2011, 02:28 PM
IvanSunn IvanSunn is offline
Vehicle: 1998 2500 Dodge Ram
Color: Brown
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
IvanSunn is on a distinguished road
Default Ram 2500 4x4 Problems
1998 Ram 4x4 Cummins
Will not engage the 4 wheel drive. Vacuum at vacuum shift motor correct. Removed CAD mechanism. Cleaned the shift fork and did not see any apparant binding or damage. The shift motor shaft appears to move correctly when vacuum is applied. It appears that the passenger side drive axle is out of align with the intermediate drive shaft. Using a small pry bar, I raised the passenger side shaft and slide the shift collar over the intermediate shaft. 4x4 then was engaged and all 4 wheels spin.
There appears to be a nose on the inner axle shaft which fits into the end of the outer axle shaft. But when the collar is slide back the 2 shafts do not stay align. The problem I am sure is that the 2 shafts are not staying in alignment. What keeps them aligned? Thanks for any help...
Old 07-18-2011, 09:50 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
While you're waiting on the answer, drop by the Newbie Checkin and introduce yourself with a fep photos.
4x4, intermediate shaft, vacuum shift motor
Power Steering and Braking Problems 2006 Dodge 2500 Mega Cab aliciahammerich Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 06-22-2013 12:22 PM
97 2500 with brake problems, can I bypass the rears tribaljack Suspension 2 10-04-2010 08:35 PM
04 ram 2500 tranny problems!!!! HELP!!!!!!!!!!! ramman23 5.7L V8 Specific Topics 4 05-01-2010 01:14 PM
94 2500 Cummins problems jcvp Dodge Ram General Discussion 3 02-21-2010 12:00 AM
2006 Dodge Ram 2500 turn signal problems joshuakline Electrical 8 02-04-2010 08:01 PM
