Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-16-2011, 11:20 PM
diverp diverp is offline
Vehicle: 2006 Dodge Ram Mega Cab Larami
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
diverp is on a distinguished road
Default Engine Revving with brake on
Hi. This is my first time on this forum. Thought I would see if anyone could give me a hand in diagnosing something. Here is my truck:
-2006 Dodge Ram 2500 Mega Cab Laramie
-Diesel, Automatic
Yesterday, a behavior started with my truck. Either hot or cold, I can be sitting at a stop with my foot on the brake. If I am in park or neutral, not problems. If I am in D, 1, 2 or R, with my foot on the brake, the transmission slowly surges/revs to advance. If I shift back into Neutral, the engine will over rev shortly, then drop back to normal idle.
If I am in any of the gears (D, 1, 2, or R), with my foot on the brake, the transmission is pushing trying to advance the truck...if I let off the brake and slowly let it rock forward, the transmission noticeably stops pushing so hard and behaves normall (all speeds are under 5 mph).
There is no check engine light. I don't have a scanner at the moment to be able to check for codes.
it would appear that it is more of a transmission issue (solenoid or torque converter issue) or a sensor/switch issue (brake switch?). Not sure. The only reason I rule out a gas/air issue is because the truck runs normally when moving at any speed and idles perfectly.
Any direction or help is greatly appreciated.
Thank you,
Paul
Old 07-18-2011, 12:18 AM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
I remember this happening with my dads truck not very long ago i will post back if i can find out anything about it.
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 07:23 PM
ABS, Brake Warning and Check Engine nashdaddy75 5.9L V8 Specific Topics 21 09-09-2010 12:15 AM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
Truck shaking when gas is depressed dirtsurferus 5.9L V8 Specific Topics 12 01-31-2010 01:19 PM
Painting Engine Cover Incognito Dodge Ram General Discussion 15 01-11-2010 10:14 AM
