Place your Ad Here!
Old 07-17-2011, 08:34 AM
jcstanle jcstanle is offline
Vehicle: 2011 dodge ram
Color: grey
jcstanle is on a distinguished road
Default whistle at 120kph, grinding at 80kph
Hi
I have a 2011 Crew Cab Hemi and I'm not pleased with all the noises I'm hearing. At 120kph or slower on a windy day I get a loud hollow sounding whistle that sounds like it's coming from the driver side, side view mirror. I've tried taping all seems from the headlights back. I've pulled the mirror in tight to the cab but the whistle still persists. Very annoying
2nd noise is a grinding sound that comes at about 70-80kph when maintaining speed in high gear. Seems to come from mid truck and occurs more readily if going up slight incline or towing my boat. I've had a friend suggest the heat shield over the exhust might be slightly loose which makes noise at a certain resonance.
Anyone have a suggestion or similar problem? I'm taking it to the dealer next week.
Old 07-17-2011, 12:27 PM
redlightrico's Avatar
redlightrico redlightrico is offline
Vehicle: 2015 Sport 4X2
Rep:15
redlightrico is on a distinguished road
The whistling I have encountered and just put it out of my mind as a design flaw. ( getting a louder muffler helps too!!) The "grinding" on the other hand I cant see being a heat shield, might want that checked by your dealer fast.
The list is soon to be long....much to my wife's dismay
Old 07-17-2011, 12:36 PM
Color: grey
I've read some other similar posts and as a result I've found the source of the whistling. When I push out on the door frame near the top front corner, the whistling goes away. I've read about 2 solutions, bending the door or replacing the door seal. Replacing the door seal seems to be the obvious thing to try first. We'll see.
Old 07-17-2011, 07:12 PM
JAMS RAM JAMS RAM is offline
Vehicle: 2011 Ram 1500
Trim Level: OutDoorsman
Color: Silver/Dark Gray
JAMS RAM is on a distinguished road
Hey,
The whistle does have a " TSB" out at the dealership I believe. They will insert foam behind the weatherstripping for a tighter fit. Supposedly this will fix it, my hasn't whistled for me yet but I'll be listening. The grinding could be low rear diff fluid level from the factory. Just read about on another forum. I would have them check the center and front diffs while they are in there locking. You'll definitely want that on your service record at the dealer ASAP. Don't except the noise, if they can't fix it within four tries, lol 2 to many in my opinion, then you may request a buy back under the lemon law. Good luck and post what the dealer does for you.
Old 07-18-2011, 11:06 AM
Color: grey
UPDATE
I got impatient yesterday and decided to fix the window wind whistle myself..and it actually worked.
I put the window all the way down, opened the door slightly and while sitting on the drivers seat (facing out the door) I braced my feet on both ends of the door (bottom corners of the window opening) grabed the top of the door where the noise was coming from and gave a couple quick pulls. If you step of the truck and shut the door you'll notice the door fits more tightly than it did previously.
I tested it up to 145kph on a very windy day and didn't hear a whisper.
Problem solved!
Old 07-18-2011, 11:55 AM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
Originally Posted by jcstanle View Post
UPDATE
Problem solved!
So you "bent" the door instead of going to the dealer and having them tape some foam? Oh boy.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 07-18-2011, 12:35 PM
Color: grey
"bent" sounds harsh. The top of the door may have moved in 1mm and the door actually appears to be more flush with the cab now. Whistle is gone and it didn't leak last night in the rain.
Now, if only I knew what to "bend" to fix the grinding sound.
Old 07-18-2011, 01:09 PM
BBRam BBRam is offline
Vehicle: 2011 Dodge Ram
Trim Level: QC Laramie
BBRam is on a distinguished road
I believe I hear the same noise from my truck, although I would describe it more as a low frequency howl rather than a grinding noise. It happens under load in high gear at around 40-50 mph. At first I too thought it may be something a little loose that's resonating at a certain frequency, such as the low rpm, but now I think its the TC because if I give it gas and the TC unlocks the noise disappears. I haven't brought it back to the dealer because its seems like one of those things that can only be heard under certain circumstances, and I haven't got the time for multiple trips back.
Debadged, Rhino Liner, stubby ant, Gorilla BC lugz, caf
Old 07-18-2011, 01:20 PM
Color: grey
Yeah similar to mine. The sound tends to come when in a high gear in a heavy load situation, just before the trany is about to gear down.
I'm booked into the dealer wednesday of next week. I'll let you know what they find/don't find.
Old 07-23-2011, 07:54 PM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Default wind noise
There is an RRT11-057 out from dodge for the wind noise. Check with your dealer.
grinding noise, sound, vibration, vibrations, whistle
Grinding noise in 4 wheel drive 03dodge4x4 Dodge Ram 4x4 - Offroad Discussion 2 12-13-2011 05:34 PM
Does your truck whistle? I fixed mine finally, here's how sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 16 03-03-2011 03:06 PM
Tranny grinding zilla 4.7L PowerTech V8 Specific Topics 4 08-17-2010 12:06 PM
2010 Ram 1500 with grinding noise XiNull LD RAM - General Discussion 4 01-27-2010 11:21 PM
Grinding noise in 4wheel drive 03dodge4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-23-2010 02:58 AM
