Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 01-28-2013, 05:25 PM
jlbutler2879 jlbutler2879 is offline
Vehicle: 2011 Ram 1500 Crew Cab
jlbutler2879 is on a distinguished road
What section at Home Depot can i find this gasket? I just got back from there and no one knew what I was talking about. I even showed them the picture the op posted of the gasket's packaging.
Old 01-28-2013, 05:56 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It's in the area with the door weatherstripping.
Sean
Old 02-01-2013, 06:10 PM
eagleleader eagleleader is offline
Vehicle: 2008 Dodge Ram 3500
eagleleader is on a distinguished road
Unhappy Rear Window Leak
Thanks for the info, just getting ready to rip everything apart to find the source of the water. Drained into both compartments under the back seats causing about $500 worth of damage to my HAM radio gear. Am going out right now to remove third brake light right now!!
Old 03-04-2013, 07:27 PM
wagon52 wagon52 is offline
Vehicle: 2006 Ram 3500
wagon52 is on a distinguished road
I starting noticing a nasty odor in my truck about a month or so ago.(2006 Ram 3500 Quad Cab) Took it in for some extended warranty work a week ago since my warranty expires in April. My good friend is my mechanic and works at the dealership so I feel comfortable with it being there. Either way, When it was in last week my friend (the mechanic) said he wanted me to bring it back in to check for a water leak because he thought that the odor was being caused by some kind of leak. Looked around the back glass while it was raining last week and noticed water in the bottom track of the power slider. didn't look any further since I thought I found the source. I removed the carpet and back wall padding that was damp and moldy. So I rescheduled and took it back today (of course my buddy was off today) and the "water leak" guru looked at it and said it was leaking from the rear window. Told me they could reseal it and it would cost $230 and it was not covered under the extended warrant, neither was the carpet. Told them to go ahead and do the repair. They called me back a couple hours later and told me that the "water leak" guru tried to repair it but couldn't and that the only fix would be to replace the back window to the tune of $725. Service guy said that the problem is there is no drains for the window and that there is an updated rear slider that has drains to alleviate the problem........I told them I would pick the truck up and to not do anymore to it. First, if that was the case then why wouldn't Chrysler replace the window under a warranty situation if they know there is a problem?
Sorry for the long winded explanation but I guess I will be looking at my 3rd brake light when I get the truck home and praying that it is the cause of my leak so it can be fixed. I'm hoping and praying that it is.
Old 04-21-2013, 12:16 AM
twp67 twp67 is offline
Vehicle: 2012 Ram
Trim Level: R/T
Color: True Blue Pearl
twp67 is on a distinguished road
Thank you! I have installed a recon 3rd brake light and sealed the gap with clear rtv and looked good and worked for a year. I'm guessing the temperature changes overtime and heavy rains of late caused it to fail. I was thinking of a "D" gasket, but the ridges in your choice would seem to give more contact.
Old 06-15-2013, 03:33 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
Another bump for new members. I just had to do this today. Many thanks to OP for saving me a trip to the dealership!
Rain-X Latitude wipers; Volant CAI - with ram air tubing; custom y pipe; Xlerator racing muffler; cats delete HemiFever custom Diablo tune; Line-X; Putco SilverLux LED headlamps; Putco Luminix LED fog lamps; Bilsteins 5100's all around, leveled up front; BFG AT KO 2's; KMC XD Battalion rims
Old 06-17-2013, 05:07 PM
Clandry Clandry is offline
Vehicle: 2006 Dodge Ram 3500
Clandry is on a distinguished road
Just discovered the leak on our 2006 Dodge Diesel Laramie. Now I know where that smell was coming from. Just did a temp fix today, but after seeing this, will attempt it at earliest convenience. Thanks for step by step and pics. Will post back after the job is done. This is a better fix than the dealer suggested; just buy a new light. They only wanted $130.00 and all I wanted was a new gasket. Figures!
Old 07-25-2013, 04:11 PM
aleekat aleekat is offline
Vehicle: 2003 Ram 1500 5.9 Hemi Quad
Color: Blue
aleekat is on a distinguished road
I'll update this. Picked up 2003 couple weeks ago. Had my daughter riding in the back in a rain shower. She saw the water dripping. Searched and found this thread. Once I pulled the 3rd brake light, just a cheap foam gasket. Squeezed it and water dripped out. Found the same product as OP at Lowes. Pretty sure that is where the leak was coming from.
Old 01-03-2014, 12:37 PM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2016 Ram 1500
Trim Level: Sport 4x4
Rep:163
Firemedic10584 has a spectacular aura aboutFiremedic10584 has a spectacular aura about
I just noticed my 2013 start leaking in the same areas mentioned in this thread. Top rear corners of the headliner and some water in the rear storage bin area. Applied some new, thicker weather stripping. Hopefully this fixes the problem. My 2011 also did the same thing. Did the same procedure with that 3rd brake light and it also fixed it.
Old 01-13-2014, 01:14 PM
Spike2014 Spike2014 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Blue
Spike2014 is on a distinguished road
Hello,
I'm brand new here. I have noticed that the windows on my 2009 frequently fog up on the inside. I have also noticed frost on the inside of the windshield when it got down in the teens to single digits last week. Mine sometimes has a slight smell to it as well.
I have not noticed any stains on the headliner or wet carpet or seats. I do not have a sliding rear window or a sunroof. I do have the satellite radio though. Does it sound like the 3rd brake light on mine as well?
Thanks.
Spike
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 16 07-02-2016 05:36 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Trailer Brake Light Problem ronanderson57 Electrical 5 04-20-2011 03:25 AM
abs light, brake light, speedo not working, stalls when stopping B and B LANDSCAPES Electrical 21 04-07-2011 09:56 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
