Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 07-17-2011, 09:39 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Default ArmyofOne's How-To Garage-Breather Filter Mod!
Hey gang, Did a cheap mod today on the ram. After the mod, took a couple of vid's and went on a little hwy trip (about 50 miles or so each way). Noticed a 1mpg increase in avg on hwy. City will probably be next to nothing...but these are V8's we are talking about.
The mod is the Deletion of the Positve Crankcase Ventilation Breather line. What this line does is:
-Rob you of a couple horsies.
-Bogs down the responsiveness of your Beasty Powertech V8 Believe me when I say, the SLHemi (Slightly Less than a Hemi) needs every pony its got.
-Robs you of 1-2mpg
-Makes your Throttle Body REALLY oily every few thousand miles.
How does it do this? Well, it takes the oily fumes and excess air pressure from your crankcase, and puts it into your intake. The pix will tell all, but the main reason I did this was so that I would not have to clean that throttle body as often. That thing gets filthy. I really did not expect any gains in either HP/responsiveness or MPG, but I was pleasantly suprised. So, without further adue...the How-To and Video results.
What you will need:
-Flathead screwdriver (Free)
-1 1/2" to 3/8" step-down hose adapter ($4.99)
-1 1/2" plug (mine came in packs of 2). ($3.99)
-The hose of the intake (pictured in the step 1 pic), or some 1/2 rubber hose. (Free, took mine off the truck)
-Utility knife to cut said hose (Free)
-2 hose clamps ($.25 ea)
-breather filter ($9.99)
Step 1- Remove airbox top, intake tube and this hose:
Step 2- Remove Breather filter from package:
Step 3- Attach Breather filter to step-down adapter as shown. Insert 3/8" end into filter hose and tighten clamp (included with filter):
Step 4- Cut Intake tube, the piece you want is the first elbow, with roughly one inch on either end of the bend. I cut mine too short, but I was able to make it work. Make Your's about 1/2" longer than this one:
Step 5- Install new/cut hose on Valve cover hole you removed the old hose from. Slide hose clamps over hose:
Step 6- Install breather filter on other end of hose, tighten clamps.
Step 7: Put a cap on hole in Airbox cover Shown in the above pic^.
Step 8: Clean Throttle Body. How-to here.
Step 9: Reassemble intake.
Step 10: Pedal to Metal.
Final Product (side view):
When I took these video's, I WAS NOT in a neighborhood. I was however on the base, so I did not want to get too crazy.
Diesel Technician-PACCAR Inc.
Old 07-17-2011, 09:50 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
My bad to whatever moderator moved this (think it was Maddog), I had multiple tabs open and accidently hit new thread in the wrong forum! Thanks for the move!
Old 07-17-2011, 09:52 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Very nice setup...simple and cheaper than a catch can!
Old 07-17-2011, 10:02 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
That was the Idea. I have done this on every car/truck I have owned. The Ram seems to benefit most out of any of them though. Altogether (counting the gas for the 16 mile round-trip to Napa/AutoZone), I am out $30.
Old 07-17-2011, 10:09 PM
916Timmy's Avatar
Rep:1443
Nice! Let us know how fast the filter gets oily!
Old 07-17-2011, 10:13 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Even when it does, it does not really "filter" anything. You can replace it, but I will probably just degrease/wash it 5 times or so, then replace it.
On my other applications they typically need cleaned once a year. So the service lifespan would be about 5 years. But I have never kept a vehicle long enough to have to replace one. Hoping my Ram will be the first.
Old 07-18-2011, 12:33 AM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Update:
OMG guys, It is crazy just how much low end power this seems to unlock! Plus it makes a really neat "whistle" at WOT. Its the sound of rushing air. Truck just seems to run so much better.
Old 10-01-2011, 07:20 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
So what's better, the little filter or the catch can?
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 10-01-2011, 07:46 PM
MADDOG MADDOG is offline
Rep:22
The filter and the catch can work in concert with one another. You gotta have somewhere for that oil filled mist to go:
Here's my little breather filter on the SRT:
Old 10-09-2011, 01:18 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
Originally Posted by ArmyofOne View Post
looks good, but couldnt you have put the breather right on the nipple on the valve cover?
Cabin Air Filter Mod ciara Heating & Cooling 1 07-01-2011 01:55 AM
how to clean the fuel filter? hemi414 Dodge Ram General Discussion 4 06-07-2011 11:27 PM
Garage Mod Roman Chariot Off Topic Discussion 14 03-30-2011 04:50 PM
New Fuel Filter For 6.7 CTD RamTech Dodge Ram General Discussion 4 09-29-2010 05:15 PM
