ArmyofOne's How-To Garage-Breather Filter Mod! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 10-09-2011, 02:01 AM
knappk6's Avatar
knappk6 knappk6 is offline
Vehicle: 2008 Dodge ram
Trim Level: Big Horn,MonsterMile
Rep:15
knappk6 is on a distinguished road
Originally Posted by mr.lopar View Post
looks good, but couldnt you have put the breather right on the nipple on the valve cover?
It looks like the filter was to small to fit directly onto the valve cover
35% tint on front, 2 JL 10W1 underseat, Kenwood KVT-514, Spectre CAI, Nitto Trail Grapplers 295/60R20, BILSTEIN 5100
Old 10-10-2011, 10:53 AM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
Yeah there was no way. The hole in that filter was TINY. Like pencil eraser size. So I had to make something work. This was it.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 07-24-2012, 06:53 AM
Jayzsun's Avatar
Jayzsun Jayzsun is offline
Vehicle: 2012 Dodge Ram crew cab.
Trim Level: st
Jayzsun is on a distinguished road
I found that you can buy different size of breathers from 9mm to 18 mm inlet....i will do that mod on my 2012 next week!I just need to take measurment in case it's not the same as you gave us.
She thinks my Dodge is sexy!
Old 07-24-2012, 07:58 AM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2016 Dodge Ram 1500 CC
Trim Level: Rebel
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
I take it this mod is for both the 4.7 and the 5.7? If anyone has done this on the hemi, have you noticed any improvement power.performance wise?
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 07-24-2012, 12:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Just an FYI, I'm pretty sure that breather hose is the breather that let's clean air into the crankcase. If so, then this mod doesn't do anything, which is fine, just an FYI.
Air enters the breather(from the filtered side of the air cleaner) and then gets circulated into the crankcase then out the PCV on the opposite valve cover.
If you do this mod you are just giving the breather it's own filter instead of sharing the regular air filter.
Sean
Old 07-24-2012, 02:45 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
HEY!!!
It looks cool none the less right
I might just do it
MATT
Old 07-24-2012, 03:11 PM
Jayzsun's Avatar
Trim Level: st
Me too!!!!But on the 2012 the hose is going to the driver side near the oil filler neck...and there is a king of black plastic square thing...don't know if i can do the mod...
Old 07-24-2012, 03:21 PM
snrusnak's Avatar
Rep:1388
That's because he has the 4.7 and you have the 5.7
Sean
Old 07-24-2012, 03:51 PM
Jayzsun's Avatar
Trim Level: st
ok...and can i do the mod?
Old 07-24-2012, 04:13 PM
snrusnak's Avatar
Rep:1388
Probably, but I'm not very familiar with the layout of the breather and pcv on the hemi. Just about every modern engine uses this setup though.
Sean
Cabin Air Filter Mod ciara Heating & Cooling 1 07-01-2011 12:55 AM
how to clean the fuel filter? hemi414 LD RAM - General Discussion 4 06-07-2011 10:27 PM
Garage Mod Roman Chariot Off Topic Discussion 14 03-30-2011 03:50 PM
New Fuel Filter For 6.7 CTD RamTech LD RAM - General Discussion 4 09-29-2010 04:15 PM
