Old 07-17-2011, 09:43 PM
chadob69's Avatar
chadob69 chadob69 is offline
Vehicle: 2009 Dodge Ram 2WD
Color: Blue
chadob69 is on a distinguished road
Default Rear Shock Replacement??
I thought the rear shock replacement would have been easy. Just take 2 nuts and bolts out, put in the new shock and bolt them back down. Does anyone have any insight as to how to get the driver side top nut/bolt out without having to drop the fuel tank. Also it's so hard to get a socket on because the nut is actually lower than the frame(or close to it). If anyone has done the rear shock replacement please let me know if I am missing something or if i need a special tool. Thanks.
Old 07-17-2011, 09:51 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Just did my drop kit this weekend and I used a breaker bar with a small socket to hold the inside bolt...breaker bar parallel to the ground pointed at the fron of the truck...akward for the person holding it, but it worked. When it was tight enough not to spin, imact gun!
Old 07-17-2011, 09:59 PM
chadob69's Avatar
Color: Blue
You did it without dropping the fuel tank? I'm guessing you took the wheel liner out for better access to the outside bolt.
Old 07-17-2011, 10:43 PM
916Timmy's Avatar
Rep:1443
That is correct, no tank drop, but the liner came out
Old 07-18-2011, 10:33 PM
chadob69's Avatar
Color: Blue
Thanks for the help, i bought a 3/8 angled head stubby ratchet and it worked like a charm. Had it swapped out in 5 minutes and didn't have to take the wheel liner out. It looks like you kept your stock rims in your photo's. What size tires do you have on there? I know it says with the CST spindles not to go any bigger than 305 without wheel spacers.
Old 07-18-2011, 10:35 PM
chadob69's Avatar
Color: Blue
the only thing i' waiting on now is the darn spring compressor so i can get the rear springs back in. After that i will take some pics and post them.
Old 07-21-2011, 08:55 PM
chadob69's Avatar
Color: Blue
Finally done. Rides just like it did before just a hint stiffer on some bumps. Just need to put some bigger tires on.
Old 07-22-2011, 02:47 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
truck looks good. I cut an extra boxed end wrench in half and was able to squeeze it in up there no problem.
Rear shock removal southpaw5m Suspension 4 05-01-2011 05:18 PM
Rear End Replacement Costs jjklongisland Dodge Ram General Discussion 4 02-19-2011 11:33 AM
Help!!! Rear Bumper replacement distributors? jwt355 2011 Dodge Ram Forum 7 02-14-2011 10:56 PM
Stock shock replacement JR23 Drive Line 2 03-17-2010 07:06 PM
97 Ram 1500 4X4 Rear Shackle Replacement deringer Suspension 4 08-14-2009 02:17 PM
