Old 07-18-2011, 12:01 AM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
Default To those who have done a 2/4 drop
Thinking about doing a 2/4 drop and was wondering if it would be possible for me to just buy torsion keys and do the rear flip without the kit. I can go out and get longer U-bolts and new shocks if that is all i need. Do i need new shocks? Is there anything im overlooking with the front suspension? Do i need to relocate rear shock mounts,will stock shackles with a flip give me 4"?
Pics of any parts metioned would help alot thanks.
Old 07-18-2011, 10:10 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-19-2011, 07:49 PM
Dalton's Avatar
Trim Level: Daytona
Rep:43
Anybody have any Ideas?
Old 07-27-2011, 10:46 AM
SDoriginal SDoriginal is offline
Vehicle: 2005 Ram
SDoriginal is on a distinguished road
Dalton,
unfortunately, this will not work. If your truck is 2wd, the front needs either drop coils or drop spindles. a torsion key will not work. As for the rear, flipping the axle while using stock shackles will give you a 6 inch drop, and you'll be hitting your frame rails unless you c-notch it (trust me, been there, done that). also, the flip kit I bought comes with a piece that creates a flat surface between the axle and the leafs. i know this is all bad news to you, but I'd hate for you to tear apart your truck just to find out these problems.
What you can do is this: 2" drop shackles from McGaughys and removal of overload leaf in your spring pack. it will get you close to 4" in the back and only cost about $75 (from timssuspensiononline). The bad news is that the truck will sag real bad with any load in it, and your tires will buzz your fenders, so some cutting and rolling of the fenders will be needed to keep your tires safe from the fender (I also made this mistake a ruined a set of rear tires).
Hope this helps, and let me know if you have any other questions, I've been around the block with 3rd gen suspension...
If it ain't a hassle, it ain't low enough...
Old 07-27-2011, 12:00 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
This is extremely important, otherwise the axle can "twist" under load. I worked with a guy that flipped his mini truck axle and leafs like you are saying and after only a couple of days of driving he ended up twisting the axle (relative to the springs) and it pulled the driveshaft out and broke the u joint and alot of other damage. It happened when he accelerated hard onto the freeway.
Sean
Old 07-29-2011, 10:46 PM
Dalton's Avatar
Trim Level: Daytona
Rep:43
Thanks for the info guys i guess i will just buy the kit.
Old 07-30-2011, 12:02 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Flip kit w/ stock shackles is 6"..... The 4" flip is done w/ 2" lift shackles.
Buy a 2" drop spring and flip w/ 2" lift shackles. Should be about $300. The thing is when you get near that money you may as well buy a kit for $400 and get all the matched components, and the little things you may need like shock extenders mounting plates for the flip, etc etc
I saved and did mine once, did it right, and dont regret waiting longer at all. Its safe and its strong. Look at McGaughys 2/4"....they have an economy drop that may fit the bill.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
K&N drop in filter mrcivic 2011 Dodge Ram Forum 20 08-01-2011 02:50 AM
CHEAP drop shocks! fowler2000 Suspension 1 05-09-2011 03:00 AM
How many coils to cut to get 2"-2.5" drop????? DodgeMyRam Suspension 1 03-02-2011 03:43 AM
Can I drop a 350 or a 318 engine in my 2002, 1500 Ram? FSam5886 Newbie Checkin! 14 06-26-2010 01:19 PM
Ball Hitch Drop Ken Towing 5 05-10-2010 08:51 AM
