Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 07-18-2011, 10:56 AM
HoosierHemi's Avatar
HoosierHemi HoosierHemi is offline
Vehicle: 2011 Dodge Ram
Rep:115
HoosierHemi will become famous soon enoughHoosierHemi will become famous soon enough
Default HOW TO: Disabling Seatbelt Chime (VIDEO)
1- lock seatbelt in
2- turn ignition to "ON"
3- wait for seatbelt warning light to remove from dash
4- remove and insert seat belt 3 times within 10 seconds
5- leave seatbelt in on the 3rd time
6- turn ignition to "OFF"
7- listen for chime to confirm operation worked
EDIT: Still not working, sorry, I'll update this if a solution is found....
2011 Black 1500 Sport QuadCab 4x4
Old 07-18-2011, 11:54 AM
Jonesey982's Avatar
Jonesey982 Jonesey982 is offline
Vehicle: 2007 Dodge Ram
Jonesey982 is on a distinguished road
Thanks for the info. I'm going to try this on my 3rd gen and see if it works.
Old 07-24-2011, 06:51 PM
Quickdrop's Avatar
Quickdrop Quickdrop is offline
Vehicle: 2011
Trim Level: R/T
Rep:14
Quickdrop is on a distinguished road
ty for this dude
2011 Ram R/T
14.33 with a 63F track temp, hopefully into 13's by end of summer
Old 07-24-2011, 08:21 PM
BgHrn BgHrn is offline
Vehicle: 2006 Dodge Ram
BgHrn is on a distinguished road
Would this work on a 06' Ram 1500?
06' Ram, molding!, In-channel visors, 3" Mag' SI/SO 18" long, Mag' y-pipe, 2" HBS Leveling kit/1" rear block ,DSP 91 tune, KN CAI kit, BFG 285/65r20 rubber.
Old 08-23-2011, 05:04 AM
tastoffel's Avatar
tastoffel tastoffel is offline
Vehicle: 2005 Dodge Ram 4x4 5.7 Hemi
Trim Level: SLT Thunder Road
Color: Atlantic Blue Pearl metallic
tastoffel is on a distinguished road
This is what I found on another forum (http://www.**************/forums/sho...ight=horn+honk). (I guess this will not show)
I haven't had time to test it yet, but my guess is that it should work.
The Enhanced Warning System (BeltAlert) can be enabled
or disabled by your authorized dealer or by
following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. The manufacturer does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver’s
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver’s seat
belt remains unbuckled.
I'm still looking to disable the horn when locking the truck and get a blink on the lights instead. Up to now I only found a way to disable both, the locking and unlocking signals.
Reducing the horn sound to a small chirp would be ok too, but not the original sound.
Old 09-05-2011, 10:16 PM
2006ramhemi's Avatar
2006ramhemi 2006ramhemi is offline
Color: Gray
Rep:50
2006ramhemi will become famous soon enough
i just tried this on my 2006 ram and it worked on the first try. drove around with it unbuckled and there was no chime. i wear my seatbelt anyway but i unbuckle when im parking or pulling up to an atm so its nice not to hear anything. when it comes on i get scared it might be the check engine light or something
Old 09-15-2011, 01:34 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
freaking sweet! i have an 08 1500 and did it before work today, and BAM no annoying chime! thanks bro reps coming your way!
-Pat-
Old 11-03-2011, 04:43 PM
Green 1500's Avatar
Green 1500 Green 1500 is offline
Vehicle: 2011 Dodge Ram 1500 QC
Color: Hunter Green
Rep:17
Green 1500 is on a distinguished road
I have a 2011 1500, and it worked. Did it yesterday.
Old 11-03-2011, 05:16 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I did this on my 05, but I buckled and unbuckled 5 times, but not as quick as you did it and it worked.
Dillon-aka, The Little Kid
Old 11-08-2011, 08:01 PM
HeyBrownDog's Avatar
HeyBrownDog HeyBrownDog is offline
Vehicle: 2011 Dodge Ram Quad Cab 4x4
Rep:20
HeyBrownDog is on a distinguished road
Worked Perfect.....thanks!!!!!
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 07:14 PM
need a how to video or book or somthing, on tb cleanup babetheox777 5.2L V8 Specific Topics 3 03-07-2011 09:33 PM
Disabling Seatbelt Chime MisterOX2009 2009 Dodge Ram Forum 46 12-30-2010 11:32 PM
Seatbelt chime disable Masher768 Newbie Checkin! 11 10-08-2010 02:24 AM
Help in disabling seat belt chime ? 08h3misport Electrical 8 12-16-2009 10:53 AM
