Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 05-24-2012, 05:20 PM
918Dodge's Avatar
918Dodge 918Dodge is offline
Color: Metallic Black
Rep:20
918Dodge is on a distinguished road
Worked perfectly in my 2010 today!
2010 Ram1500/SLT/RCSB/+Hemi
Old 06-02-2012, 09:36 AM
jeljr2003 jeljr2003 is offline
Vehicle: 2007 Dodge Ram Sport 1500
jeljr2003 is on a distinguished road
I'm still looking to disable the horn when locking the truck and get a blink on the lights instead. Up to now I only found a way to disable both, the locking and unlocking signals.
Reducing the horn sound to a small chirp would be ok too, but not the original sound.
The horn chirp feature will be shipped from the assembly plants activated. If desired this feature can be disabled by using the following procedure:
1. Perform this operation while standing outside the vehicle.
2. Press and hold the LOCK button on a programmed (i.e. functional) key fob.
3. Continue to hold the LOCK button, wait at least 4 seconds, but no longer than 10 seconds, then press and hold the PANIC button. Release both buttons at the same time.
4. To reactivate this feature, repeat the above steps.
Vehicles will be shipped from the assembly plants with the park lamp flash feature activated. If desired, this feature can be disabled by using the following procedure:
2. Press and hold the UNLOCK button on a programmed (i.e. functional) key fob.
3. Continue to hold the UNLOCK button, wait at least 4 seconds, but no longer than 10 seconds, then press and hold the LOCK button. Release both buttons at the same time.
Old 09-07-2012, 08:45 PM
Mac48383 Mac48383 is offline
Vehicle: 2012 Dodge Ram
Mac48383 is on a distinguished road
Default Thank you
Worked on my 2012 Big Horn 4x4. Thank you, thank you, thank you!!!
Old 09-15-2012, 06:50 PM
sjustice sjustice is offline
Vehicle: 2012
Rep:23
sjustice is on a distinguished road
Post Seat Belt light and buzzer
Just unplug the buckle under the seat, take the plug off it bracket, cut the plug off then strip and join the two wires together insulate and done no more light and no more buzzer.
Old 09-24-2012, 11:28 PM
918Dodge's Avatar
Rep:20
Bad advice IMO.
Altering anything at all especially electrical, voids the warranty.
Old 10-03-2012, 10:17 AM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
The unplugging of the connector under the seat doesn't work on 2011 and newer I believe. On my 3rd Gen, once the connector was unplugged all you had to do was insert a 100Ohm resistor into the vehicle side connector pins. This would disable the ding and light without splicing or any major modifications. With the 2011 and newer they got smart as the used a hall effect sensor inside the buckle latch vs a simple resistor multiplex circuit.
I haven't had time to mess with it further as I usually wear my belt anyway, and simply having the ding gone for rides around my property is sufficient. I am putting my energy into trying to disable the "Black Box" code so I don't have something monitoring my every move.. More to follow in another thread...
Old 10-31-2012, 05:07 PM
BlueRamMan34 BlueRamMan34 is offline
Vehicle: 2012 Dodge Ram Laramie
Color: True Blue Pearl
BlueRamMan34 is on a distinguished road
Pure awesomeness! Thanks!!!!
Old 01-15-2013, 07:12 PM
maxjerome28 maxjerome28 is offline
Vehicle: 2008 Dodge Ram Quad Cab 4X4
Trim Level: st
Rep:16
maxjerome28 is on a distinguished road
Finally got it to work on my 08. Turned off all my accessories like hear lights radio. I did it the five times and a little slower than the first hundred times I tried it and it worked like a charm!
Old 02-05-2013, 10:31 PM
AODRN AODRN is offline
Vehicle: 2012 dodge ram
Trim Level: express
AODRN is on a distinguished road
That worked well. I hate the stupid horn when I am coming in late at night. The last thing I need at 2 am is my neighbor getting cranky.
Also the seatbelt chime worked on my 2012. At least I got the single chime to signify it worked. I will check it out tomorrow I guess.
Old 02-06-2013, 07:38 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
So do you have to do this each time you get in or does it turn it off permanently ?
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 06:14 PM
need a how to video or book or somthing, on tb cleanup babetheox777 5.2L V8 Specific Topics 3 03-07-2011 08:33 PM
Disabling Seatbelt Chime MisterOX2009 2009 Dodge Ram Forum 46 12-30-2010 10:32 PM
Seatbelt chime disable Masher768 Newbie Checkin! 11 10-08-2010 01:24 AM
Help in disabling seat belt chime ? 08h3misport Electrical 8 12-16-2009 09:53 AM
