Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 08-14-2011, 09:30 AM
Tonk Tonk is offline
Vehicle: 2011 Ran 1500 Crew Cab
Trim Level: Long Horn
Color: Hunter Green
Tonk is on a distinguished road
Default Major Water Leak Driver Side
Hello all , New to the site. I just picked up my Ram 1500 Crew cab. It's not even a week old. Today it was raining and I got in the truck only to discover the wkole driver side of the truck to be soked. I drove to a local store and on the way water was pouring down from the handle by headliner. It's Sunday so the dealer is closed. What do you think I should have the dealer do outher than repair the leak ? . I'm concerened about all the electronics being soaked rust develping and the carpet and padding becoming molded and stinking.
Old 08-14-2011, 10:00 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
If it's leaking at the front, then it's likely the drain tube from the sunroof. Not common, but it has been known to happen that the tube is not connected at the factory.
If it's leaking at the back, that is more common, and is likely coming in at the High Level Brake Light. When it's here, often the back storage compartments under the back seat will fill with water.
Either way, your dealer will take care of it. I am not aware of anyone having any negative affects from either of these leak issues, other than the inconvenience at the time, so wouldn't fret about it too much. It's a bummer when this happens with a new vehicle, but stuff happens, and that is what warranty is for.
brad
Interested in one of my mods?
Old 08-14-2011, 10:07 AM
Color: Hunter Green
No sun roof. The leak is most likley comming thru the wind shield. The whole dash and floor is soaked.
Old 08-14-2011, 10:12 AM
brad12kx's Avatar
Rep:2581
That is very uncommon. I have only ever heard of one other with a leaking windshield, and that was after it was replaced, so yours is somewhat 'special'.
Let us know what the dealer discovered and how the repair goes.
brad
Old 08-14-2011, 12:55 PM
Color: Hunter Green
Just went out and discovered that the headlinner is dripping water over the drivers side door. The size is about 1 foot X 1 foot. Put a tarp over the roof. HELP !!!
Old 08-14-2011, 10:11 PM
hendog0311 hendog0311 is offline
Vehicle: Ram 2010 Reg Cab 4x4
Color: inferno red
hendog0311 is on a distinguished road
Mine had a leak in that same spot as yours. The windshield wasn't sealed correctly from the factory. They removed the windshield and resealed it. Good to go now. Hope yours gets fixed.
Old 08-14-2011, 10:48 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. I'm here to help you navigate the site so after the leak gets fixed drop by the Newbie Checkin and introduce yourself to everyone with a few photos.
Old 08-15-2011, 02:01 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
defently make that appointment when the dealer reopens
Old 12-05-2011, 07:44 PM
fiddlinbluegrass fiddlinbluegrass is offline
Vehicle: 2011 Dodge Ram
Trim Level: Larime
fiddlinbluegrass is on a distinguished road
Default Water Leak
I have a 2011 Ram 3500 and have a water leak on the drivers side leaking from the handle on the window arm, I took it to the dealer 3 times and just sent it back, after getting my truck back the 3rd time it was leaking worse than before. The truck does have a sun roof but they said it was not leaking, they sealed the cab lights, 3rd break light and said they never found the leak!!! They just came and picked it up again, not sure what to do now...
New trucks should not be in the shop more than in your drive way!!
Old 12-05-2011, 08:04 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
ask a friend to help you
you go in the truck looking for water leaks while your friends use the garden hose to simulate rain on the truck, windshield, doors, brake light, handle, sunroof,... etc
then when you know were it leaks from tell the dealer,..
or tell the dealer to do all of that, after all its warranty
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
A/C low pressure valve leaking sonocativo Heating & Cooling 56 06-05-2013 05:40 PM
2005 ram 1500 a/c duct hot air from passeger side witha/c on cool air driver side duc kscot Heating & Cooling 5 08-27-2011 09:48 PM
Having trouble with my driver side low beam SapperRam1500 Custom Dodge Ram Interior and Exterior Lighting 3 02-15-2011 10:10 PM
driver side mirror shakes GoManGo420 Dodge Ram General Discussion 7 05-14-2010 09:46 AM
driver side door speaker problem Quiet Lunatic Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 06-12-2009 01:59 AM
