Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 07-19-2011, 01:07 AM
nikeman nikeman is offline
Rep:91
I just looked it up on usps.com and shipping to canada would run me about $10 if I send it in a small package.... I would be willing to ship to canada if your willing to pay to have it sent to my house and then pay me $10 to ship it to you... Also trust is an issue as well since I am not well known around here, I understand..
Old 07-19-2011, 02:28 AM
Driver CH Driver CH is offline
Vehicle: 2011 Dodge Ram Laramie
Driver CH is on a distinguished road
Originally Posted by nikeman View Post
now can someone tell me why in every picture and video that I see of this thing, its always installed on the drivers side? Does it really matter what side its on? Does it come with directions that tell you to put it on that side? I read on here of someone noticing that it was scratching the paint right beside the damper and they had to put tape around it to prevent that. Should I just put tape around it from the get go or has anyone else noticed this scratching?
look http://www.youtube.com/results?searc...+install&aq=0L here...
Old 07-19-2011, 07:32 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Just ordered one, thanks for the info 300Mag. I left more rep for you.
Old 07-19-2011, 09:38 AM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
Thanks , cant wait to get it in. Nice budget friendly mod
Old 07-21-2011, 06:37 PM
jdubsss's Avatar
jdubsss jdubsss is offline
Vehicle: 2011 Dodge Ram 1500
Rep:112
jdubsss will become famous soon enoughjdubsss will become famous soon enough
I don't know who else has tried to install this yet but I got mine today and went to try the install (referring to the sachs part 300MAG recommended, not the DEE ZEE).
Everything goes smoothly (the instructions are pretty good) until step 3. You're supposedly to insert the threaded insert with bolt assembly into a hole on the driver's side tailgate. On the 2011 Ram (my ram anyway), we don't have a regular circular hole as shown in the directions, it's much wider than the kit shows. See pictures.
At this point I just stopped (didn't have anything lying around to try and rig it up with) and will put in for an RMA. The DEE ZEE kits fit this at it uses something entirely different here all together.
Mods: 14" Magnaflow Muffler, AirRaid CAI, Recon Smoked LED Tails, Recon Smoked LED 3rd Brake, Recon White Lightning, 6k HID Fogs, White LED Plate Lights, LED Interior Lights, EZ Down Tailgate, 20% Tints, Pillar Tape Removed, Stubby Antenna
PICS: http://www.ramforumz.com/showthread.php?t=87696
Old 07-21-2011, 06:55 PM
Lothario80 Lothario80 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Color: Mineral Grey Metalic
Rep:41
Lothario80 is on a distinguished road
Identical to my 2011... This sucks!
K&N CAI - Magnaflow 18" - Putco In-Channel Vent Visors - Truxedo Lo-Pro Tonneau - 5" Carbon Fiber Antenna - Timbren SES - Smoked Tails & 3rd - Overhead 13" DVD - CHR550 Lockpick - DeBadged
Old 07-21-2011, 08:25 PM
Rep:23
not for nothing but I never recommended nothing, I only stated what I just purchased and why. I would never recommend anything I have never tried. With that I did install mine today as I don't care for it either but not exactly for the same reason but similar. the piece you mentioned actually secures very well and tight into the oval hole(it's operates like a wall anchor as you tighten the screw the fingers expand from behind to secure in place and keep in mind this is hard to remove once installed)....no problem with it being oval, but the piece is brass and than they have you screw a steel ball stud into the brass part which they tell you do not overtighten. the force of the gas shock strips out the brass threads very easily for one. also while I don't have a comparsion I would have thought the shock support would have slowed down the tailgate more than it did. I'm not sure if it is normal since I have never seen one in action up front and in person, but it is a stablius gas shock whick appears to be the same brand the DeeZee kit uses based on the installion video on there website.
Old 07-21-2011, 10:27 PM
jdubsss's Avatar
Rep:112
No one is blaming you for it buddy, so calm down :}
Mine did not expand at all...dunno if it's just a faulty part or what but I went at it for 20 minutes or so before finally just saying forget it. And if you look at the DEE ZEE kit they don't use the balls or anything like that and the piece that gave me trouble is just a normal nut that you slide into that space sideways.
Old 07-21-2011, 10:56 PM
Rep:23
I'm calm bud just didn't want anyone to get the wrong impression from your post.
As far as you having trouble based on your pictures the whole assemble that gets inserted into the oval hole has to be tight, yours appears to be loose. If you tighten the assemble up and insert it in the hole. You then hold the screw in place with allen key or hex head socket while you tighten the nut, this will expand the brass fitting. It takes all of 5 minutes to do but I do agree the whole assembly could be better.
Old 07-21-2011, 11:32 PM
Rep:91
great! I was looking forward to putting mine on tomorrow but now I am thinking about not even opening the package (if it comes tomorrow) and just returning it...
Should I install it or return it and get a DeeZee?
