Old 07-18-2011, 03:11 PM
kmick77 kmick77 is offline
Vehicle: 2011 Dodge Ram 1500 QC Sport
Trim Level: sport w/Ram Air Hood
kmick77 is on a distinguished road
Default Info regarding lifting my 2011 Ram 1500 Sport
Any information is greatly appreciated. Originally i was going to use a READYLIFT 2.5" front end kit. Now i'm not so sure it will work. The wheels/tires I am going with are: XD 20"X10" Rockstars wheels with Toyo Open Country M/T 35"X12.5 tires. I dont want the huge lift look on the truck. I'd only like to lift it the minimum amount for these tires to fit. Any advise would be great since this is my first lift.
Thanks in advance.
-Ken
Old 07-19-2011, 05:08 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
You will rub with those size tires due to the width depending upon the wheel offset. I think youll need -12 offset to clear, but thats not 100% for sure on the 20x10 wheels. With a -12 offset, you should be OK on 9" wheels. Maybe someone running that size can give you a definitive answer.
As far as height goes, you should be ok provided you get the correct offset of wheels to set them out a bit.
DS Trinity w/ custom tune, S&B Intake, ARH LT Headers, Magnaflow Cat-back, 87mm PTB, BT Catch Can, 180* T-Stat, v6 E-Fan, 5000k RS HID, XD Misfits w/ 35"x12.5"x18", Rancho QL level, 5% tint w/ 35% full windshield, Hifonics Brutus 1100.1 w/ Sundown SA12 in ported FoxBox
Old 07-19-2011, 07:30 PM
I think you're right. So after some research i'm looking at a -24 offset giving me backspace of 4.55". The lift i'm going with is a Heavy Metal Suspension 3" levelling kit in the front and 1.5" lift in the rear. They've guaranteed me it will fit 20"X10" wheels with -12 offset or more with the 35"X12.5". I'll post some pix once its done in a few weeks.
Thanks for the insight.
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
NEW 2011 1500 sport GTaBeZ Newbie Checkin! 12 05-09-2011 12:58 PM
I made a deal on a new 2011 Sport Today ehenson99 2011 Dodge Ram Forum 12 05-07-2011 03:32 PM
Rear springs on 2011 1500 Sport northernblue Suspension 2 04-22-2011 11:27 PM
2011 ram 1500 locker Pigpen 2011 Dodge Ram Forum 5 02-27-2011 07:53 AM
