Old 07-18-2011, 05:08 PM
elliottw elliottw is offline
Vehicle: 1996 Dodge Ram
Trim Level: Lt
Color: Green
Rep:25
elliottw is on a distinguished road
Default New Member, First Ram- Wipers don't work
Howdy all,
I just bought my first Dodge, I needed a work truck and this nice 96 Ram 1500 is what I got. It has the 318 magnum and a 5spd tranny but on to my first post. My windshield wipers dont work, it blows the 20a fuse as soon as I turn on the key.
It doesnt matter if the switch is set to on or off. I think there is a short somewhere, would it be the switch on the lever on the column or could my wiper motor be shorted out? I tested the fuse box with a light and it only gets power when the key is turned on too.
I took the panel off under the dash and the wire looks ok as far as I can see between the switch and the fuse box, but i couldnt get the wipers removed to get the wiper cowl off, if someone could tell me how to do that too? Does anyone have any insight that could help me with my problem? I would definately appreciate it. Thanks.
Old 07-19-2011, 08:05 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Have you tried disconnecting the motor and seeing if the fuse blows? And if you have a volt meter you can test for a short across different paths. I'd start with the motor.
Old 07-19-2011, 10:52 AM
atvfamly atvfamly is offline
Vehicle: 1999 Dodge Ram Sport
Color: Banana
atvfamly is on a distinguished road
Thats a good place to start.
Old 07-19-2011, 01:26 PM
Trim Level: Lt
Color: Green
Rep:25
Sounds good, could you tell me how to remove the wipers lol. Is it that little "L" shaped clip that you pull out? Because I tried to do that and it kinda smashed the one end of that clip. And where is the motor, drivers side, pass side, middle?? But ill give the motor a try as soon as I get the wipers off. Thanks
broken, dodge, motor, wipers, working
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 07:23 PM
dealer refuses to do warranty work.... saunders1986 Dodge Ram Warranty Issues 32 04-11-2011 02:07 PM
2010 March - Dodge Ram Member Of The Month BlueJet 2010 Dodge Ram - MOTM - Archives 43 03-13-2010 08:16 AM
2010 February - Dodge Ram Member Of The Month BlueJet 2010 Dodge Ram - MOTM - Archives 51 02-13-2010 10:01 PM
