United Radio
Old 09-30-2013, 08:50 PM
thkbaron thkbaron is offline
Vehicle: 2011 ram sport crew 4x4
Rep:61
thkbaron will become famous soon enough
Default Camber Bilstein 5100
So I haven't gotten my alignment done yet, but when people do this install are the adjustments to the front as far as alignment go pretty much being done to adjust the camber? I'm sure there is some side to side adjustments that will need to be done, but from what I can see I just see the obvious positive camber.
2011 Ram Sport 4x4 Crew Cab
Old 09-30-2013, 08:59 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
You are correct sir in indicating the apparent positive camber after leveling the front. The shop I took my truck in for alignment did the Camber and Caster adjustment as needed.
Old 09-30-2013, 10:16 PM
Rep:61
did they have to put any additional parts in it to do so, or just messed with what was there?
Old 09-30-2013, 10:41 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
They just adjust what's there, no extra parts. My camber was off as well as the toe. An alignment is a must if any kind of levelling is done.
New Signature Pic Pending
Shorty Antenna, Recon 3rd Brake & Xtreme LightBar, DeeZee Tailgate Assist, MOPAR Valve Caps, Lighted RAM hitch cover, Tints (20% frt),Bug deflector, LED Interior Lights,.
Old 09-30-2013, 11:16 PM
Rep:61
sweet good to know so if they try and put some parts in I'll know they're trying to screw me! I appreciate it!
Old 10-01-2013, 10:01 AM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
I assume you already have the billstiens installed. What setting did you use? If this is the case and you just need an
alignment they should not require any additional parts.
Old 10-01-2013, 11:53 PM
390hemi's Avatar
390hemi 390hemi is offline
Vehicle: 2012 Ram 1500 Sport
390hemi is on a distinguished road
I just leveled mine on Saturday, 2.8 setting with a tgc 3/4" spacer in the rear an got it aligned yesterday. My camber, caster, and toe were all out of wack camber being the worst of course. In and out in an hour with everything back in spec and riding like a dream.
Happy to say not the slightest vibration in 4x4 or any other mode for that matter. I absolutely love it and would recommend 2.8 setting to anyone. 3" body and 35's soon :-)
Bilsteins at 2.8", 3/4 coil spacer, 3" pa body lift, 20x10 wheels on 35/12.50/20 trailgrapplers
