Old 07-19-2011, 12:06 PM
devsoul's Avatar
devsoul devsoul is offline
Vehicle: 1999 Dodge Ram 1500
Color: Yellow
devsoul is on a distinguished road
P0420 Catalyst Effect
Old 07-19-2011, 12:33 PM
atvfamly atvfamly is offline
Vehicle: 1999 Dodge Ram Sport
Color: Banana
atvfamly is on a distinguished road
Hmmm...........
Old 07-19-2011, 09:27 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
well guys i hate to interupt on you guys thinkin its only 99 sports but my 98 2500 has been doing that since winter. iv changed every sensor on my engine and complete tune up plus the 02 sensor before the cat. still does it. only personwhos givin me a decent idea of what it is was my brother in law who said it was a bad intake manifold gasket. not the plenum gasket that makes you burn oil. theres another gasket supposedly that does it. so thats what iv been told but im too broke to bring her to the shop for their opinion on it. so id say look there and let us all know how it turns out.
Old 07-19-2011, 10:18 PM
devsoul's Avatar
Color: Yellow
I am taking it to a garage after work tomorrow to have my cut out welded back in the converter. I will stop and get a small methane torch, if it is a blown gasket causing a vacuum leak I should be able to find the leak with the torch(unlit of course).
Old 07-20-2011, 12:47 PM
Color: Dark Red
well hopefully you can get it figured out and give me some more insight on how to fix mine too. good luck.
Old 07-20-2011, 10:28 PM
devsoul's Avatar
Color: Yellow
Default Problem solved, almost!
Here we go.
I took the truck and had my cut out welded back in the converter. I had an idea on my way home that since my converter was empty I didn't need the new O2 sensor I just put in. I thought I could use the plug off of the old sensor, plug it in where the front sensor goes, bare the ends, push them in the sensor plug and use the back sensor instead. Well, the plugs are different sizes. So I decided to leave the front one unplugged and see if I still had the problem. It is running good now. The computer must go into a default setting when it senses the O2 is unplugged. I sugest unplugging your O2, one at a time to see if it helps. The front one plugs together right above the transmission, the rear on the side. I am going to leave it unplugged and see how it runs for a couple of days.
If anyone knows how to post video, I will get it running bad before I replace the sensor and post it so you can tell better if this is the same problem you are having.
I also took my cap off and cleaned the rotor last night. That seemed to help it run smoother. Going to change those soon also.
Let me know if this was any help.
Old 07-20-2011, 11:34 PM
Color: Dark Red
well my front 02 sensor i replaced this past spring so that should be fine. possible the back one needs replacing. just cant wait to get the crap out of my cat so my exhaust flows good. hopefully everything will make it run good.
Old 07-21-2011, 09:53 AM
devsoul's Avatar
Color: Yellow
It ran fine all the way to work this morning
Old 07-21-2011, 03:06 PM
devsoul's Avatar
Color: Yellow
This answers the problem I was having-
HTML Code:
http://www.justanswer.com/dodge/4qgod-dodge-ram-1500-4x4-02-1500-5-9-gas-150000-mi-runs-rough-within.html
Thanks to deanthecrabman!
5.9l, iac, o2 sensor, rough running, vacuum
Sucking sound??? bigred0603 4.7L PowerTech V8 Specific Topics 9 03-06-2011 12:58 PM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
help..noticable different sound in engine nitro1965 5.7L V8 Specific Topics 4 01-19-2011 03:17 AM
Loud Whomping Sound, i'm completely stumped. Any ideas??? stlpunk13 Suspension 7 11-11-2010 03:26 PM
Headlights and running lights wont work at the same time, but work Indivdually??? komodo1982 Electrical 16 12-21-2009 08:53 PM
