Old 07-19-2011, 12:15 AM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
Default PCM/Computer reset...
Hello all. When I had my 2004 I could reset the ECU by removing fuse #23 in the frontal control module(Fuse box), turn the ignition key to start(Nothing would happen) , then turn it off and re install the fuse. This would come in handy at the track as it would reset the "how you drive" learn process. On the way to the track I would drive aggressively and notice slightly better times. Is there a similar process for the 2011 Rams? Thanks in advance for the help...
Old 07-19-2011, 12:48 AM
jdubsss's Avatar
jdubsss jdubsss is offline
Vehicle: 2011 Dodge Ram 1500
Rep:112
jdubsss will become famous soon enoughjdubsss will become famous soon enough
I've read here disconnecting the negative battery cable will reset EVERYTHING, that might be what you're looking for.
Mods: 14" Magnaflow Muffler, AirRaid CAI, Recon Smoked LED Tails, Recon Smoked LED 3rd Brake, Recon White Lightning, 6k HID Fogs, White LED Plate Lights, LED Interior Lights, EZ Down Tailgate, 20% Tints, Pillar Tape Removed, Stubby Antenna
PICS: http://www.ramforumz.com/showthread.php?t=87696
Old 07-19-2011, 12:53 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
also touch the two disconnected battery cables together to drain the circuits faster.
Old 07-24-2011, 10:53 PM
VvgrovervV's Avatar
VvgrovervV VvgrovervV is offline
Vehicle: 11' Ram Sport
Color: Blue
Rep:21
VvgrovervV is on a distinguished road
takes along time for this to take effect though
How to reset change oil light? Mikes2010Ram 4.7L (287 cu in) PowerTech V8 Specific Topics 6 02-21-2012 10:05 AM
Cheat Sheet for reset of Oil Change prompt? rsg1963 2010 Dodge Ram Forum 7 11-23-2010 10:25 AM
Oil Monitor Reset Question Mr. Ed Cummins Diesel Specific Topics 4 10-03-2010 08:20 PM
Adaptive learning table reset, yes or no? GPSHSLAX Dodge Ram General Discussion 16 07-14-2010 04:07 AM
Reset average gas mileage counter texasf Fuel System 7 10-24-2009 02:22 AM
