Valiant 6RT Keyless Entry - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-19-2011, 12:01 AM
Dooner's Avatar
Dooner Dooner is offline
Vehicle: 2010 Dodge Ram 3500 DRW 2wd
Color: PDA-Light Greystone Pearl
Rep:20
Dooner is on a distinguished road
Default $30-Valiant 6RT Keyless Entry (answered)
I purchased a Valiant (IC Dynamics) keyless entry and wondered if anyone has used one.
It came with more than what I thought. It has door lock/unlock and truck lock/unlock which can be used for the tailgate with another relay module and power lock solenoid.
I'm trying to figure out how to hook it up to my 2010 Ram 3500 crewcab. I checked the wiring on that builders site, but am more confused.
Anyone have something that will help. If not, I will call CS tomorrow.
Thanks
Dooner
2010 Dodge Ram 3500 DRW 2wd and 1964 Plymouth Belvedere 4dr Sedan
Old 07-19-2011, 12:35 AM
Dooner's Avatar
Rep:20
Here is a link to see what I am talking about.
http://www.jcwhitney.com/model-6rt-r...wx?filterid=j1
Dooner
Old 07-19-2011, 11:43 AM
Dooner's Avatar
Rep:20
Ok guys, here is what I got from CS at icdynamics.com. So if you can figure this out, you can add $30 keyless entry to your 2010 Ram. There are other year models on the web site. If yours isn't there, use the feedback form.
I'll let you know how it does.
Vehicle Make: Dodge
Vehicle Model: Ram 3500
Vehicle Year: 2010
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED ( +) @ BATTERY
STARTER SEE NOTE #1
STARTER 2 N/A
IGNITION 1 PINK/WHITE ( + ) (NOT USED FOR REMOTE START) @ IGNITION
NODE, ON IGNITION SWITCH
ACCESSORY/HEATER BLOWER 1 SEE NOTE #1
ACCESSORY/HEATER BLOWER 2 N/A
PARKING LIGHTS ( - ) WHITE (- THRU 1000 OHM RESISTOR) @ HEADLIGHT
SWITCH, PIN1, BLACK 10-PIN PLUG
PARKING LIGHTS ( + ) WHITE/LT.GREEN (LEFT) ( + ), WHITE/PURPLE
(RIGHT) ( + ) @ POWER MODULE, PINS 48 AND 50 , BLACK 50-PIN PLUG
POWER LOCK PURPLE/LT. GREEN (TYPE-) THRU A 330 Ohm Resistor,
PASSENGER DOOR LOCK SWITCH, GREEN 10 PIN PLUG, PIN 8
POWER UNLOCK Same wire, (TYPE-) THRU A 100 Ohm Resistor
NOTE #1: This Vehicle is Equipped with CHRYSLERS MULTIPLEX
IGNITION/ANTI-THEFT SYSTEM
that requires a INTERFACE BYPASS MODULE for REMOTE
STARTING
Dooner
Old 07-19-2011, 05:11 PM
Dooner's Avatar
Rep:20
I purchased the three resistors needed and ready to install. I'll take pics of the progress and post.
If this works out, you can have keyless entry for less than $50. Less money on the locks, means more money for other mods. I like that.
Dooner
Old 07-22-2011, 12:48 AM
Dooner's Avatar
Rep:20
OK. It's installed and works great. It took me a little longer to install than I hoped, but I had Daddy duties and sometimes I like running wires the wrong way and have to do it all over. That's just the way I roll.
But seriously, it works great. You need to install two resistors and hook it to ground. Another good thing about this $30 device, is that it is expandable. You can add remote start, alarm, and hook up a power solenoid to the tailgate lock.
Also, IC Dynamics has a great customer service. They helped me understand what I needed to do, and gave me the right wire colors and locations.
I recommend this to guys that don't want to spend the $$$$$ for the factory unit.
Dooner
Keyless Entry? Rogers Rams 2010 Dodge Ram Forum 28 02-01-2011 09:44 PM
OEM Remote Keyless Entry for 2007 Ram 1500? MayoBoy LD RAM - General Discussion 10 08-05-2010 12:23 PM
98 Ram Keyless Entry (3/4 of the way there) strang3majik Electrical 6 06-19-2010 09:04 AM
2004 Durango Keyless Entry Doesn't Work TenneSST Other Vehicle Discussion 4 02-28-2010 06:49 PM
Factory keyless entry question sherfield2002 LD RAM - General Discussion 16 12-01-2009 11:28 PM
