Old 07-19-2011, 03:46 AM
Raneman's Avatar
Raneman Raneman is offline
Vehicle: 2004 Dodge Ram
Rep:22
Raneman is on a distinguished road
Question Boring TB? Intake sensor?
If its possible without a special expensive machine, How would I bore my TB on my 2004 hemi? And what should I use to clean my TB?
If i put pvc from the TB to the airbox, what do i do with the sensor?
Mopar or no car
Old 07-19-2011, 10:16 PM
BossHog9110 BossHog9110 is offline
Vehicle: 1994 Dodge Ram
BossHog9110 is on a distinguished road
i would never bore the tb without a mill or something with a digital location read out, you dont wanna **** anything up, your holes should be dead centered. go slow and use plenty of oil, then you can clean it with oil and air, carb cleaner if you wanna get dirt and grime off. but the tb does get pretty hot, i dunno how hot but id make sure the pvc will hold up, and id figure out a way to hook that sensor back up, or get a delete sensor for it
Old 07-19-2011, 10:59 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
you can use a tuna can as a template...I've seen guys do real good work with a dremel tool an tuna can...
Old 07-19-2011, 11:01 PM
chefred112's Avatar
Rep:656
pvc an sensor...
Old 07-20-2011, 04:06 AM
Raneman's Avatar
Rep:22
pvc an sensor...
Is there a thread showing that install? Or a similar one? And thanks!
Mopar or no car
Old 07-21-2011, 07:27 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
i have pvc piping all the way to my filter, drilled a whole in the 90 degree bend to plug my sensor and i have it all painted...are you asking for a write up?? and i cleaned my TB with carb cleaner and man oh man that S**T was dirty!!!
-Pat-
Old 07-21-2011, 12:44 PM
Raneman's Avatar
Rep:22
Well id really appreciate a write up
So id know what size and angles and connections to use ya know. And im modding my airbox today, running some pipe to the fog light hole, hopefully that turns out good.
Mopar or no car
Old 07-21-2011, 03:42 PM
BlackHemI's Avatar
Rep:296
im at work right now, but the parts can all the bought at home depot.
1-90 degree street bend elbow
1-2 foot long section of 3" pvc pipe
1-90 degree elbow
1-3" coupler
1-pvc cement(although i didnt use it on the pipe that my filter is connected to the last bend just incase i wanna change it out and it is tight in there!)
1- spectre cone filter (after you take out your stock airbox, there is TONS of room for a huge filter!!)
then the hardest part, find a bracket or mount (i fabricated one) thatll bolt up to the 8mm?? or 13mm?? hole from your airbox
-Pat-
Old 07-21-2011, 08:45 PM
chefred112's Avatar
Rep:656
sorry no..I did this back in 05.. I remember using 4" dia pvc... 1 - 90 degree elbow, 1 - 22 degree elbow, 1 - straight 4" short connector, 2 - 3" to 4" rubber connectors (for each end), and 2 - 4" rubber connectors to tie in the pvc together..
Old 07-21-2011, 11:24 PM
BlackHemI's Avatar
Rep:296
if you dont mind waiting i will take pics tomorrow of how mine looks sorry i just got off so late been workin, 6-6 long days!!
-Pat-
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
XTRA POWER MOD moved IAC sensor from Manifold to Intake tube RAMING IT Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 05-09-2011 09:05 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
over head console ram man Electrical 1 10-17-2010 01:41 AM
