Painting Calibers - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 07-27-2011, 02:23 PM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2017 Dodge Ram 1500 Crew
Trim Level: Laramie 4X4
Color: Delmonico Red Pearlcoat
Rep:31
11HEM1 is on a distinguished road
It really is an easy thing to do. Dont sweat it. Clean the calipers with the cleaner that is in the kit wipe down them mask off what you dont want paint on and paint do all four then add another coat ( when I was finished with the forth one I started on the second coat) Let them cure/dry for 2 hours I waited 1.5 because it was so dang hot and put your wheels back on The kit says not to drive for 24 hrs I waited about 18 hrs again because of th heat here. here is a picture of the whole truck but you cant see the rears
Old 07-27-2011, 05:16 PM
Peppas Peppas is offline
Vehicle: 2007 Dodge Ram
Trim Level: Quad Cab 4x4
Color: Electric Blue Pearl
Rep:24
Peppas is on a distinguished road
very nice, i plan on doing them myself but haven't picked a color, started a thread to get opinions on what color to use.
It is here.
http://www.ramforumz.com/showthread....697#post577697
Old 09-19-2011, 01:28 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
If you have a second person around that can help you later pull the calipers off and clean the heck out of them (also lets you paint the back of the pads if you want) then throw em back on and have someone help you bleed the brakes. Gets some fresh fluid in there as well
2011 Big Horn 4x4 -SnowWhite-
Need tips for DIY dash and door bezel painting plz. ramrat Body & Interior 6 04-26-2011 06:00 PM
touch up painting Excoastie Other Vehicle Discussion 5 04-19-2011 10:36 AM
Painting plastics jwsnowman Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 11 02-23-2011 06:39 PM
Grille Painting gdeezy Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 14 02-09-2010 04:06 PM
Painting Valve Cover Questions. 98sst LD RAM - General Discussion 21 11-02-2009 12:20 PM
