Heater Problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 07-19-2011, 07:58 AM
mclovin7794's Avatar
mclovin7794 mclovin7794 is offline
Vehicle: 2002 Dodge Ram
Color: Grey
mclovin7794 is on a distinguished road
Default Heater Problems
Greetings,
I am having problems with my heater. It will not heat up at all unless it is running for 20+ minutes. It started near the end of winter up here (Alaska) and I want to try and get it fixed before winter hits again. Any advice? Thanks.
Grab life by the horns.
Old 07-19-2011, 12:48 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Hmmmmmm....sounds like your thermostat is taking too long to open. I can't think of anything else that would be a direct cause of that issue. Good news is a thermostat is cheap and relatively easy to change. That's what I would try first anyway. If your thermostat is not working properly even the slightest bit, it needs to be replaced anyway before it costs you your engine.
Old 07-19-2011, 10:49 PM
Color: Grey
Ok. I'll try that. Thanks!
Old 07-19-2011, 11:38 PM
Rep:367
Unless it's different on your truck the tstat should be located in a little housing where the lower radiator hose meets the block. I think you take out two bolts and remove the whole housing to get to it. Just pop out old and throw in new. Only thing is you need to drain the coolant first or you are going to make a mess when you take the housing off. If you catch the coolant in a clean container you can reuse it.
Oh yeah, make sure you get the tstat back in oriented the right way and the gasket on it is intact. I'm not sure if there is a gasket between the housing and the block but there would probably have to be. The parts place or your dealer should be able to tell you.
Old 07-30-2011, 09:03 PM
Color: Grey
So...before I did the tstat job, I had a few friends who worked on trucks check it out and found out that my heat only blows on the passenger side but not the driver side. I read a couple of the other threads on this site and I think it might be the heater core. Any thing else it might be? Thanks.
Old 07-30-2011, 10:07 PM
Rep:367
If you haven't already, read this.
http://www.heatertreater.net/Ram%2002-08%20Listing.html
If you have some time on your hands all of it is good info to have tucked away just in case but section 2 (blend door), specifically paragraph "b" seems like it may apply to you.
Failure of these HVAC doors seems fairly common on the Ram trucks. I didn't think about this before because even though I have read through that entire site before, my problem is the recirc door. I haven't bought one of these kits yet but I may eventually.
I think your problem is either the blend door or a clogged heater core and I would lean toward the blend door. Maybe trying the heater core and hose test as described on the website will help you determine. Good luck!
Old 08-06-2011, 06:49 PM
Color: Grey
Thanks. That would be a good thing to look into.
Heater problems odj22sailor@gmail.com Heating & Cooling 22 11-29-2014 04:28 AM
Any one else have heater defrost problems? BRYFRY 2009 Dodge Ram Forum 10 02-22-2011 03:20 AM
Heater and AC control problems juniormag Heating & Cooling 12 06-07-2010 08:26 PM
Heater problems owenm Heating & Cooling 6 12-12-2009 01:38 PM
Heater Problems jsirmg LD RAM - General Discussion 3 11-15-2009 05:09 PM
