Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 07-19-2011, 12:04 PM
hotchiliram's Avatar
hotchiliram hotchiliram is offline
Vehicle: 2011 Dodge Ram 1500 4x4 Sport
hotchiliram is on a distinguished road
Default Where to install airlift command and compressor
Hello, I bought a Airlift 1000 for my truck and I also bought a Firestone compressor with single gauge.
I'm having a hard time figuring where can I install the gauge and the compressor, I don't want the compressor to be exposed to dirt, water, etc... so the engine bay is not an option, I was thinking inside one of the rambox but I'm not sure.
Where did you guys installed your compressor and gauge?
Thanks
2012 CTD Laramie Crew Cab
Old 07-20-2011, 09:21 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I haven't had experience with your needs but would think the rambox would work for the compressor. That'd be a great place to keep it from inquisitive eye's too.
Old 07-20-2011, 10:03 AM
Yeah, that's what I was thinking, I'm going to install the gauge inside the center console.
Thanks
Old 07-20-2011, 12:19 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I don't know how big the compressor is, but I mounted a small compressor for air shocks on another truck to the frame rail in front of the rear tire, I had full wheel well covers so it wasn't exposed to any road debri/rain/etc... (unless you do reverse burnouts...) I liked this option as it was completely out of the way...there is alot of space along the outer frame rails on trucks. I only had to crawl under and wipe some dust off of it about once a year, it really didn't get dirty hardly at all.
Sean
Old 07-20-2011, 12:31 PM
Thanks, I'm going to install it inside one of the RamBox, I don't want to take the risk to have it where water, debri, etc... can catch it.
Old 07-20-2011, 02:49 PM
riggz riggz is offline
riggz is on a distinguished road
If you do install it in the ram box, you might want to make sure it is shielded from any other items that would be in there. Compressors can get hot if they are running a lot. Also I don't know how well the RamBox seals, but if it has a really good seal, you would need to run the air intake line outside of the box otherwise you would create a nice vacuum inside the RamBox and possibly burn out the compressor.
Old 07-20-2011, 02:55 PM
snrusnak's Avatar
Rep:1385
^^Good point. And also if the ram box leaks water in it could ruin the compressor. Maybe make sure the ram box can drain out any water that might get in...
Sean
Old 07-21-2011, 09:02 AM
Excellent point, the Ram Box is pretty sealed, I haven't had a single leak in any.
I'm going to think again where can I install it, Maybe inside the engine bay?
Thanks for the Info.
Old 07-21-2011, 11:12 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I think you will be fine in your engine bay, If you look under your hood, most of what you see is just dust, which shouldn't harm the compressor at all, and most permanent install auto compressors can handles minor exposure to moisture. Plus you won't lose space in your Rambox.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 07-21-2011, 11:17 AM
snrusnak's Avatar
Rep:1385
how big is this compressor? picture maybe?
Sean
