Old 07-19-2011, 09:46 PM
Subhunter's Avatar
Subhunter Subhunter is offline
Vehicle: '11 Ram 1500 Reg Cab Hemi
Trim Level: Optioned out SLT
Color: Cherry Red pearl
Rep:16
Subhunter is on a distinguished road
Default 2011 Stock backspacing and offset
I'm sure this has been asked and maybe answered before but I can't find it using the search function. Probably not framing my search phrase right. Anyway, I'm planning to swap the stock silver painted 20x8" alloy wheels on my 2011 SLT for something more appropriate in the fairly near future and trying to get my ducks in a row before then. I don't want to put out a bunch of bucks and find out the new wheels won't fit so I'd like to know what the offset and backspacing is on my stock five spoke alloys. I would think it's listed somewhere but not having any luck, further, none of the folks at the tire shops, aftermarket dealers or even at the RAM dealership know. All I get is shrugs. Does anyone here know or maybe have an unmounted wheel they've measured?
Old 07-19-2011, 11:57 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
+19.05mm offset, thats straight off my 2010 20x8 painted wheel. It gives the dimensions of the wheel and offset amount once the tires are unmounted.
DS Trinity w/ custom tune, S&B Intake, ARH LT Headers, Magnaflow Cat-back, 87mm PTB, BT Catch Can, 180* T-Stat, v6 E-Fan, 5000k RS HID, XD Misfits w/ 35"x12.5"x18", Rancho QL level, 5% tint w/ 35% full windshield, Hifonics Brutus 1100.1 w/ Sundown SA12 in ported FoxBox
Old 07-20-2011, 08:14 PM
Subhunter's Avatar
Rep:16
So it's printed or stamped 'inside' the wheel? Figures, you'd think they would put that in the owners manual. You'd also think somebody at a tire shop or dealership would have it handy. The wheels I'm looking at are 20x9 with a +20mm offset and the outfit selling them said they would fit but didn't want to just take their word for it. Many thanks Doz.
Old 07-20-2011, 11:22 PM
doz doz is offline
Rep:76
With a +20mm offset you wont want to go more than about 12" MAX and thats cutting it close. I have 295-70-18 Nitto TG's and they are like 11.7" wide and get mighty close to hitting the upper control arm.
Old 07-21-2011, 01:43 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Agreed. What profile tire were you looking at getting?
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 07-21-2011, 01:52 PM
Subhunter's Avatar
Rep:16
Thanks to both you and Doz for the good inputs. The truck is going to get a 2/4" drop soon. The wheel I'm thinking about is a 20x9.5 with a +25mm offset that the dealer says should fit. Once my wallet recovers I'll probably end up with either 285 or 295/50's if they'll work. Opinion?
Old 07-21-2011, 05:09 PM
E.L.D. 44's Avatar
Rep:388
I don't know how the drop will affect rubbing, or if it will at all. My wheels are 20x9 0 offset and my tires are 305/55/20 a/t hankooks. My tires stuck out 19mm more than stock and I rubbed at full turn to the right until I got my truck leveled. Now I have more sidewall and a wider tire than you, but you have a larger offset. I think 295s would be ok but I would go with 285s to be safe...
MY MOD THREAD
Old 07-21-2011, 07:02 PM
Subhunter's Avatar
Rep:16
Thanks for the advice ELD44, it's much appreciated. I've been burnt more times on wheels and tires then I'd like to admit and would like to avoid it this time. Your suggestion not to push past 285's sounds good. Once I get my original 275/60's mounted back on the new wheels and get a good eyeball on my inside clearances I should have a clearer picture as to how much larger I can go without rubbing. My prime concern was the width and offset of the new wheels and from what I've learned here it sounds like they'll be ok. It's tough finding a wheel I like that fits this truck. That 5 on 5.5 lug pattern is killin' me.
Old 07-21-2011, 11:13 PM
E.L.D. 44's Avatar
Rep:388
Keep in mind that if there is rubbing issues you could always use spacers to give you s little more clearance. So you have a pic of the rims you are wanting?
MY MOD THREAD
Old 07-23-2011, 04:21 PM
Subhunter's Avatar
Rep:16
Yeah, I will use them but only as a last resort, never really liked to but that's just me. Right now I'm planning on these wheels
http://www.elementwheels.com/proddet...001b%2D095%2Ds
2011 20x8 wheels, backspacing, offset
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Need offset & backspacing for stock 17" rims rclipic Dodge Ram Wheels And Tires 1 05-29-2011 12:43 PM
Backspacing and offset questions and suggestion for a sticky moparmanicac Dodge Ram Wheels And Tires 3 02-17-2011 01:29 AM
Stock 20" Wheel Dimensions - offset backspacing Digipenguin Dodge Ram Wheels And Tires 2 10-04-2010 10:41 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 02:28 AM
