Dodge Ram Decals
Old 07-22-2011, 12:43 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Originally Posted by jdubsss View Post
hey ELD which reverse bar did you get...the recon?
No. I actually have two different bars stacked on top of each other. Both are oracle. They took two smd strips and soldered them together. They did this for both bars. I've heard really good things about the Recon though. Actually, I haven't heard anything bad about anything they produce...
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 07-22-2011, 09:18 AM
NolaRam's Avatar
NolaRam NolaRam is offline
Vehicle: 2009 Ram 1500 Crew Cab TRX
Trim Level: TRX
Color: Detonator Yellow
Rep:29
NolaRam is on a distinguished road
Super clean and great transfomation. Looks awesome. For what I guess is the zillionth time posted, (didn't read the whole thread, just looked a the great pics) any thoughts on have just the driver side R/T stripes? Super clean white truck.
Old 07-22-2011, 07:39 PM
E.L.D. 44's Avatar
Rep:388
Do you mean the hood stripes I have on there now or something else?
MY MOD THREAD
Old 07-23-2011, 10:07 PM
E.L.D. 44's Avatar
Rep:388
Default New Mods...
Okay, so I enlisted some help from 916Timmy today and finally finished some mods I have wanted to do for a while...
MGP Caliper Covers-
I will be honest I am not impressed with these. Maybe I got a bad set, but they don't cover the whole caliper in the rear and I have one rubbing in the front that I will attend to once by rotors cool off. As far as looks go these are glorious as Tim would say. Here's how to do it...
TOOLS NEEDED-
Jack
Stand
8mm socket wrench
Whatever you need to get your wheels off(I have a locking lugnut, and need extensions due to the deep well to get to the lugnuts)...
The cover
Center cap off
HOLY COW THAT WHEEL IS HEAVY!!!
Doesn't quite cover the whole rear caliper
Installed
Very simple install, just slide brackets onto the caliper and screw down a 8mm nut onto the bracket.
MY MOD THREAD
Old 07-23-2011, 10:11 PM
E.L.D. 44's Avatar
Rep:388
Another install pic-
It hurt a little to see my baby like this! Thank God we worked quick! LOL
Random Bilstein Pic- Thanks Tim! lol
Close up of the rear-
Close up of front
Front
MY MOD THREAD
Old 07-23-2011, 10:24 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Glorious! Except for the rear not covering completely and the front rubbing!
Old 07-23-2011, 10:29 PM
E.L.D. 44's Avatar
Rep:388
Default More Mods...
Fastman TB-
I plan on doing some engine work in the future when the tuners come out so I got the larger tb. It is bored to 84mm all the way thru and has a larger butterfly with the bar relocated to the back of the tb. I know I didn't need it now, but I had it and wanted it on. LOL.
Tools needed:
8mm socket wrench
First off, I disconnect the battery on everything I do. I know you don't need to, but if I do it every time I don't forget it that one time I do. After that I disconnected the the intake sensor and pulled my CAI off the tb. I also removed the engine hat.
Disconnect the tb harness, and take out the 4 bolts holding it. They are 8mm heads. It's that simple! Pic of the old tb next to the new tb
Backside
New one bolted back in
Very simple mod! I don't know if I will tell a difference in the truck since I don't have a tuner. Dan said I may even lose some low end, but I should gain top end. I guess there is one way to find out. If I do I can always put my stock one back in untill the tuner...
BT Catch Can-
This is how lazy I've been since it's gotten hot. I have had this bolted in and ready to go and never hooked it up because it was late and I was hot and tired. I know. I know. Sad. I got it. One of the reasons I wanted Tim to come over and help me. I knew I couldn't back out of it then. ha ha. Anyway, there are better threads for this install and we were getting hot so forgot about the camera. Here is the finished product.
180 Degree Thermostat-
Tools Needed:
13mm socket
Cresent wrench
Again sorry for no pics. We kinda forgot about the camera at this point lol. It was 104 today and I wanted to play golf this morning so we didn't start until 2:30. Very, very simple. Disconnect the radiator hose off the engine block. Just follow the hose that runs across the top of the fan down to the motor. While it is off I would replace that stupid factory clamp. Those are a pain! I put down a drip pan but the coolant hits the crossmember and goes everywhere. You will spill some! Then remove the neck. It has two 13 mm nuts holding it on. Behind that you will see the thermostat. If your motor is warm at all be careful. That thing is hot! Remove it and take the gasket off the old one and put it on the new one and button everything back up. Poor the coolant back in and watch your baby run cooler. My is running 185 on the highway and 188-192 city streets which isn't bad considering how hot it is right now. Very easy mod and well worth it. Autozone part number 4128
Pic of the Rams
Thanks again Tim!!!
MY MOD THREAD
Old 07-23-2011, 10:32 PM
E.L.D. 44's Avatar
Rep:388
Thanks again for helping. I will go out in a few and see if I can't bend that clip back. I bet it just is too wide. Take a pair of pliers and bend it in a little and good as new. Hopefully I don't have to take off the tire to do it...
MY MOD THREAD
Old 07-23-2011, 10:48 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
this is one amazing thread bud........reps for you
Old 07-24-2011, 03:10 AM
RIRam27 RIRam27 is offline
RIRam27 is on a distinguished road
Great job !!! best of luck with future mods and keep the pictures coming.
Saunders1986 Build Thread... saunders1986 Custom Dodge Ram - Complete Builds 6 04-10-2013 10:03 PM
Wildcat Build Thread Wildcat Custom Dodge Ram - Complete Builds 16 07-05-2011 10:18 AM
Just Got My Build Sheet highlandchef 2009 Dodge Ram Forum 11 05-24-2011 05:12 PM
09 Dodge Ram- build thread sor far D0922 Custom Dodge Ram - Complete Builds 12 02-18-2011 11:28 PM
Build Thread toysoldier3646 Custom Dodge Ram Interior Modifications - Custom Audio / Video 59 04-29-2010 04:01 PM
