Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 07-20-2011, 04:02 PM
simicar simicar is offline
Vehicle: 2003 dodge ram 1500
Rep:22
simicar is on a distinguished road
Default max boat/trailer weight
Was driving down the street the other day with my 8 y/o son and he said "Dad, you know what would look great with this truck? A boat!" I agree completely and so I am now shopping. I have a 2003 Ram 1500 Quad Cab, 6.5' bed 4.7L V8. It has no tow package, so I need to get one installed of course. Two questions:
1) What hitch would you recommend?
2) What's the max combined weight of the boat and trailer I can get? Need to be able to add a couple hundred in gear and still have a cushion as well.
Old 07-22-2011, 09:02 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Here's a link for you to look at: http://www.dodge.com/bodybuilder/year.pdf
Hope it helps! Try the specs for 2004.
Old 07-22-2011, 09:43 AM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
The web link above is great.
Also, look at the driver's side door jams for gross and rear axle weightings. You have the right idea in terms of factoring in your gear. When you get a boat and trailer, the boat will have a maximum capacity plate that will indicate the max weight of the boat, the motor(s) and gear. Also, your trailer will have a GCVW tag/plate, which is the total combined weight of the trailer, boat, motor and gear. Never exceed the GCVW of the trailer.
If you do not yet have a hitch (looks like you do not), get a class III or IV (it will depend on the max towing capcity of your particuliar truck). You should also get a 7 pin wiring harness as all boat trailers have lights (and some have hydraulic brakes) that will typically require a 4 or 5 pin set-up. So long as you have a 7 pin, you can get an adapter to fit any pin set-up your trailer may have (4,5 or 6).
Have fun with the boat. I have a power boat and love it.
Poll on oil weight you use in your 5.7 Mcbride 5.7L (345 cu in) HEMI V8 Specific Topics 45 02-27-2012 07:23 AM
Tire weight differences? snrusnak Dodge Ram Wheels And Tires 5 04-16-2011 03:30 PM
Whats the most weight you have had in the bed of your ram? ArmyofOne Dodge Ram General Discussion 40 01-14-2011 04:57 PM
