Power Steering Problem (2005 Ram SLT) - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 07-20-2011, 09:37 PM
fireatmanny fireatmanny is offline
Vehicle: 2005 Dodge Ram 1500
fireatmanny is on a distinguished road
Default Power Steering Problem (2005 Ram SLT)
I own a 2005 Dodge Ram SLT 1500, recently I noticed that my power steering has been going out intermittenly and losing power, not sure if its just the pump going out or a bigger issue. Power steering fluid is full so it has me confused. Anyone out there have had this problem before that can be of help on the cause of the problem? Any help is appreciated, thanks.
Old 07-23-2011, 10:18 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about posting a few photos of your truck?
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-23-2011, 10:41 PM
Has the fluid been changed recently? Worn out fluid will cause pump cavitation and make the steering kind of intermittent and jerky.
If the fluid is new and it's full, then I suspect the valve body that directs fluid to either side is wearing out or fluid is leaking past it in the opposite direction of the flow direction.
2005 1500 slt, dodge ram, power steering, power steering pump
Where do you stand in the 1/4 chefred112 Drag Racing Discussion 162 08-16-2012 07:25 PM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
Power steering leak johnsf Suspension 2 10-10-2010 04:59 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 12:08 AM
Power steering fluid leak rockymtnmopar Cummins Diesel Specific Topics 5 05-04-2009 07:57 PM
