Old 07-21-2011, 03:27 PM
Saabnut's Avatar
Saabnut Saabnut is offline
Vehicle: 1998 Dodge Ram
Trim Level: Laramie SLT
Saabnut is on a distinguished road
Default 46RE - no shifty
My intro thread here has most of the info but here's a recap:
Tranny blows front planetary somehow, destroys entire unit. I have it rebuilt. After installing rebuilt tranny, it won't shift out of 1st gear (reverse OK) I've tried:
Replacing speed sensor
Removing TV cable
Adjusting TV cable
Removing trans relay
removing 8-pin connector at trans
"Resetting" PCM (unplug batt, wait, plug back in) (someone suggested it somewhere)
None of these have given me any results, except for when I pull the trans relay or 8-pin connector, it does go to limp mode. [Not sure, will try again tonight, but I swear pulling the relay only gave me limp mode for one quick burst - when I stopped at a stop sign and accelerated again I swear it was back stuck in first]
What else can I do here? I don't exactly have access to a DRB, or a second "known good" PCM to try, nor do I have the cash to pony up for either right now as I just busted my wallet on this damned rebuild. Help plz?
Broken exhaust &transmission, seatbelt light stays on
Looks good sitting in the driveway though :)
Old 07-22-2011, 08:49 AM
Saabnut's Avatar
Welp I'm not sure what I did differently last night but apparently something worked. It started shifting so I'm calling it good (enough for now I guess)
Lock this or delete
Old 07-22-2011, 10:46 AM
Saabnut's Avatar
Haha, just kidding. I made it two blocks this morning (4 stops and starts) before it locked itself again! First, it would shift fine. Then, it took it a bit to start shifting, but it did. Then it would only hit 1st and 2nd, then when I turned around to start heading back home it locked back into 1st.
What do you think? I'm doubting it's PCM at this point, heading more towards a faulty governor pressure sensor/solenoid. Thoughts? Ideas? Anything else to test before I pull the transmission out again and toss it on the rebuilder's front doorstep?
Old 09-04-2011, 10:51 AM
ShadowHawk
Did you ever get the shifting problem worked out? My 2001 5.2L v8 (auto tranny) occasionally won't shift out of 1st gear just after starting it up... then other times, it's like it's stuck in 2nd, 3rd or OD, and I' have to manually shift to 1st, 2nd, then Drive when coming off of a stop sign or red light.
My gas mileage is consistently 11-12mpg in city, and if I "grandma drive" while on the highway, I might get 12-13 mpg on the highway.
I'll be changing out the Tranny Speed sensor today (about $20 and 10 minutes to do) - and will report back as to whether it helps...
Rex S.
46RE from 2wd into a 4x4? utahluge 5.2L V8 Specific Topics 2 05-02-2011 09:06 PM
46re problems FIXED...... Ram Tough 5.2L V8 Specific Topics 2 04-30-2011 03:28 AM
46RE manual TSuppa 5.9L V8 Specific Topics 1 06-02-2010 07:32 PM
46re to 5spd rhysell07 5.9L V8 Specific Topics 0 05-02-2010 03:25 PM
46re problems aroising 5.9L V8 Specific Topics 2 12-17-2009 03:34 PM
