Old 07-22-2011, 04:46 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Default 3'' leveling kit too much?
Hey guys, wanting to know if a 3" leveling kit is too much, cause i know if i do a 3" leveling kit i can fit 35" tires, but is it to much on the suspsension, or would it be safer to go with a 2.5"? cause either one im pretty sure i can fit 35's, but with the 3" it'd be better?
thanks
Old 07-22-2011, 11:40 AM
lafrance1500 lafrance1500 is offline
Vehicle: 2005 dodge ram 1500 4x4
Color: bright red
lafrance1500 is on a distinguished road
If the truck looks leveled with the 2.5 and the tires fit you should be fine and the truck would look great, and if its look more leveled with the 3 then i dont see a problem with that either, either way you should be fine
Old 07-24-2011, 11:44 PM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
I was told by a local off road shop that leveling 3" was too much because it puts a lot of stress on ball joints and other suspension parts.
Old 07-25-2011, 12:11 PM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
Well with the straight axle it won't be a problem with ball joints only thing that may be a issue would be the pitman arm not bring dropped, but you could get a new pitman arm it steering isn't right
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 07-25-2011, 03:00 PM
Color: Mineral Gray
Rep:177
When you put 3" on the front it will also pull the axle almost 3" to the drivers side with out an adjustable track bar. I would say 3" is too much.
The best way to make the decesion on a "leveling" kit is to measure from the center of the axle to the lip of the wheel well in the front and the back and the difference will tell you what to go with
Old 07-25-2011, 10:44 PM
canuk's Avatar
canuk canuk is offline
Vehicle: 2006 dodge ram slt quad
Color: metalic red
Rep:32
canuk is on a distinguished road
Default 3 inch lift
I have a 2006 1500 with 20 inch factory wheels, I put a two inch leveling kit on and it looked great. Got the death shake . I was told it has to come off , I wasnt happy , spent lots of money installing it. Decided to go ahead and get it aligned . It worked , The truck looks great and rides like factory. They were two inch spacers but raised the truck more than 2 inches. I personaly wouldnt do a 3 inch leveling kit. your asking for trouble, My two inch kit puts the front end geometry to its limits. I think i can put 35s on mine . Ill send you a pic if you want. Let me know . Vern PS in this pic, these wheels are 20 inch w 275 65 20. not far from 31s. put a 3 inch lift kit in and save yourself major headaches
Old 07-26-2011, 07:31 PM
unrealtrip's Avatar
unrealtrip unrealtrip is offline
Vehicle: 2008 Ram Big Horn 4x4
Rep:27
unrealtrip is on a distinguished road
After you installed the level kit did you get it aligned, or not until you had death wobble?
I've got a shotgun a rifle and a four wheel drive...
Old 07-26-2011, 08:56 PM
canuk's Avatar
Color: metalic red
Rep:32
It ran good after install,but not in 4WD, IT SHOOK at 5mph. I got it alligned and was lucky, could have gone either way.so im told .
Old 07-26-2011, 09:23 PM
canuk's Avatar
Color: metalic red
Rep:32
Just one more thing, since I put the 2 inch lvlg kit on,it also shifted the wieght more to the back and now it<s starting to squat
Old 07-26-2011, 09:42 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I think 3" will put too much stress on components.
Dillon-aka, The Little Kid
08ram1500 2.5'' leveling kit?..yae or nae? IBEWMAN756 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 28 02-25-2014 11:55 PM
leveling kit plus suspension lift Jerkbait Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 11 03-15-2011 02:47 PM
2WD Leveling Question bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 11-18-2010 08:20 PM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 10:20 PM
Leveling Kit - Do or Don't? Advice Please JLM89cuddy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 17 06-30-2009 02:46 AM
