Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Place your Ad Here!
Old 07-22-2011, 01:19 PM
dennisandkristen's Avatar
dennisandkristen dennisandkristen is offline
Vehicle: 1999 Dodge Ram extended cab
dennisandkristen is on a distinguished road
Default Remove or not to remove
Doing some rust removal and reconditioning of the undercarriage of a 99 1500 ext. cab short bed. The bed has been removed and in the process of cleaning up I will be coating everything with Rust Bullet (alternative rust coating product ideas welcome) Because of the difficulty in getting all the loose scale off I want to grind off the rivets and remove the cross members to do a through job. Is this a good Idea and is it sufficient to replace the rivets with grade 8 hardware when reassembling? If this is going to hamper the integrity of the frame I'd rather not.
Old 07-22-2011, 02:37 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Got some pictures? That'd help those of us not able to see what you are thinking about help you.
Old 07-22-2011, 08:00 PM
Default Pics so you can see what I'm doing
Here are a couple of pics so you can see what I'm into. The rivets I'm most concerned with hold the rear stub on and also attach the front spring shackle bracket to the frame on both sides. My main concern is the integrity of the frame where the rear stub attaches to the front frame. I would be removing the rear(spare tire) cross member and the cross member at the front spring shackle as pictured. Again at assembly would grade 8 hardware be a suitable substitute for the factory rivets?
thanks, Dennis
Dash removal twisted54 Body & Interior 10 04-06-2017 09:00 AM
Heating & Cooling grioux Heating & Cooling 3 01-27-2011 12:53 PM
Removal of transmission MrDodge300 5.2L V8 Specific Topics 2 01-16-2011 03:49 PM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
spark plug remove moparmike07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 06-04-2010 11:54 PM
