What do you dislike about your truck? - Page 6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-03-2011, 09:13 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
I just wish my truck would stay together and quit ****ing up. 18.2k miles and been in the shop 8 times since December '10. First 6 months was all good. After December, it's been in and out of the shop for all kinds of BS
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 08-04-2011, 07:23 AM
polarihog's Avatar
polarihog polarihog is offline
Vehicle: 2011 Dodge Laramie 4X4
Color: Black Metalic/ Gray bottom
polarihog is on a distinguished road
I don't have mds on my truck, but I think if you bump the gear indicator down to "5" on the evic display, like if you were going to shift manually, and leave it there it will disable mds...
that only works on the 2009 and newer models...08 Laramie doesn't have a console shift nor a manual shift mode..so..I'm stuck with buying a tuner..
Old 08-04-2011, 07:42 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yeah that sucks sorry to hear that. I bought my 2010 used and it has 48k miles now, basically no real problems; had the third brake light leak that cost me ~$10 and 30 minutes to fix, and that's really the biggest problem I've had...
Oh sorry didn't realize it was different! Gotta hate when they first introduce options sometimes you get stuck in situations like you are in...
Sean
Old 08-04-2011, 09:31 PM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:59
glcarter will become famous soon enough
After one month with my 2500:
1. No lock-out hubs
2. No dump on the drivers seat, geting something out from behind the seat is a pain waiting on the electric seat to go forward
3. Grill does not go up with hood, makes it harder to get bugs out of the radiator
4. TPMS sucks cannot run what wears best for pressures
Just picking brains, mine's worn out!
Old 08-04-2011, 09:35 PM
snrusnak's Avatar
Rep:1388
1. No lock-out hubs
I also liked the way the grill was attached to the hood for cleaning the radiator....what do you mean about the tpms? I can run more pressure without any issues...
Sean
Old 08-05-2011, 08:54 PM
glcarter's Avatar
Rep:59
I always used chalk accros the tread then drove forward 20-30 feet then looked to see if the chalk had worn off evenly across the tread. Most times unloaded the front only needed 35-40 psi and the rear 30-35 psi to get even tread wear when empty. With TPMS I have to run 60 psi in the fron and 40 in the rear for "light load". The rear is the only one ajustable at 70 psi loaded 40 psi unloaded the front remains the same at 60 psi reguardless.
Old 08-05-2011, 09:03 PM
snrusnak's Avatar
Rep:1388
wow ^^ somethings wrong with your tpms then, the truck is "designed" to have like 37psi in the tires (according to the door label) and the tpms should not set a light until low 30's psi. I did the chalk trick as well and run about 45 psi all around.
Sean
Old 08-06-2011, 04:21 AM
glcarter's Avatar
Rep:59
Door label on my 2500 with load range E tires is 60psi front/70psi rear for loaded, and 60psi front/40psi rear unloaded. When changing to loaded from unloaded found out tonight the TPMS is off by 2psi. Digital tire guage read 70psi, TPMS read 68. Low pressure light would not shut off till TPMS read=70psi. Took 10 miles to get pressure built up.
Old 08-06-2011, 08:15 AM
snrusnak's Avatar
Rep:1388
sorry didn't realize you were a 2500....
Sean
Old 08-06-2011, 08:51 PM
Joedawgs Joedawgs is offline
Vehicle: 2010 Dodge ram 1500 Quad
Trim Level: Bighorn
Color: Deep water blue
Joedawgs is on a distinguished road
head rests do suck. you can't lean ur head back.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
My truck got hit yesterday. GeauxHunting LD RAM - General Discussion 41 11-19-2010 02:15 PM
Dirt Builds Up in the Bed of My Truck Rocky Harbour 2010 Dodge Ram Forum 4 05-27-2010 12:23 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
