Old 07-23-2011, 02:58 PM
stealthvegas stealthvegas is offline
Vehicle: 98 ram
Color: red
stealthvegas is on a distinguished road
Default hhhhheeeelllllllpppp and hi
just wanna start by saying hi and thank you to all that help,i got a 98 ram with a 5.9l i cant get the pinging to stop i just fixed a vacume leak and that helped but any time i put load on the motor it just pings and pings like its runnin crapy gas and help or ideas
Old 07-23-2011, 03:44 PM
Sounds like it is running lean. Check your throttle body and clean that. Check your egr and if it's all gummed up, replace it.
You didn't mention what octane fuel you are using. 87 octane in hot conditions doesn't work too well with the 360.
Also, one last item is to have a shop check your timing. It may be off.
Good luck and Welcome To The Forum!
Old 07-23-2011, 09:58 PM
Vehicle: 98 ram
Color: red
could you tell me where the egr is and maybe how to clean the tb thanks for your help
Old 07-23-2011, 10:04 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about heading over to the Newbie Checkin and posting a few photos of your truck? I'm sure someone will point you in the right direction to find the EGR.
Old 10-03-2011, 10:36 PM
MLH07 MLH07 is offline
Vehicle: 1998 dodge sport 1500
Trim Level: sport
Color: red
MLH07 is on a distinguished road
I'm having the exact same issue with my 98 5.9. I reset the computer and it helped for awhile but the pinging is back again. If anyone knows how to get this issue resolved it would great.
Old 10-03-2011, 11:14 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
EGR went away when OBD II came in, in 1996. Sounds like the dreaded intake belly pan gasket is leaking. From a consumer standpoint, this thing is the worst thing ever sold to the public, but it sure does drive up the service dept. work. You can check by crawling up on the engine with a flashlight and looking down into the throttle body. If the intake floor is dark and oily, you got a leaker. It'll only get worse. Ante up.
