Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 07-24-2011, 07:03 AM
97greenbeast 97greenbeast is offline
Vehicle: 1997 Dodge Ram
Color: Green
97greenbeast is on a distinguished road
Exclamation Axle Shaft, front differential
Hi, Im going to sort of skip the intro as a newcomer because i need immediate help. I have a 97 dodge Ram 1500 5.2L V8 4x4 and i recently broke my inner and outer axle while four wheelin'. I have the part to replace it but my main question is is there supposed to be a bearing that is supposed to be on the inner shaft between the seal and I guess the knuckle that connects to the U-joint eventhough that's pretty far to measure from. also this is on the front passenger side.
sorry, its hard to explain its just that The inner shaft seems very clean in one spot and I was thinking that maybe that rotated in a bearing and kept it clean.
any advice will help thanks
Old 07-24-2011, 08:03 AM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:589
Hello and welcome to the forum great to have you here. sorry i can't help.
RICHARD
14" Magnaflow,87mm TB, Vararam CAI,Diablo Trinity 91 Perf ,Edge 3000 Stall T/C, Tinted tail and 3rd brake light, rally stripes,Halo LED 55W HID projectors, LEDs inside and out, and many more options.
Old 08-28-2011, 03:50 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
No bearing (carrier bearing) accessable from the spindle end. Theres one accessable from the diff, plus seal, real SOBs, apparently, I haven't yet had the personal pleasure, but my time's coming, I've only torn up the left side axle joints, relatively easy fixes.
Old 08-28-2011, 04:11 PM
Color: Green
Default thanks
Yeah thanks man for replying, I kind of just went through with the repairs and fixed it all up real quick. She is back up and running.
4x4, axle, differential, shaft, u-joint
Front drive shaft "squeaking" 05QCHemi 5.7L V8 Specific Topics 5 03-10-2013 03:14 PM
Front Axle Question tomcatg Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 10-25-2010 09:27 PM
front axle 99 ram slt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 01-14-2010 07:40 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 09:25 AM
Front Axle swap and other info Crazy Canadian Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-12-2009 07:05 AM
