Help! tiny scratches! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 07-25-2011, 10:20 AM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
Default Help! tiny scratches!
I debadged my truck yesterday and when I was cleaning the driver side door I noticed alot of very small scratches.
I used goo gone and a small "chisler" plastic tool for working bubbles out of window tint.
The best way to describe what happened is that the 3M adhesive protected the paint I was trying to remove the badges from, but the paint around where the 3M adhesive was has small abrasions.
If you look closely in the right light you can see where "RAM" used to be with tiny scratches basically outlining the removed letters.
These are very small scratches and I should be able to buff them out with my PC. My question is what polish should I use to do it?
Would my buffing pad and Meg's quik detailer be good enough or do I need a little more grit?
Thanks for helping!
Old 07-25-2011, 11:26 AM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
Thanks for helping!
If you have a PC and pads, don't you have any polishes? You will definitely need a good polish if not a compound for the reason that you created scratches, not just swirls. And if you can see the badge outline, it is probably due to the paint under the badge not being exposed to the sun and elements like the surrounding paint. Post pictures if you can and good luck!
Old 07-25-2011, 12:06 PM
M.Scipione's Avatar
Rep:41
I would typically use my PC and buffer with Meg's cleaner wax but I have recently switched to Collinite IW.
This is not paint fade, I know thats what it sounds like but what the actual issue is that the 3M adhesive was protecting the paint from my scraping, except where it did not exist (around the emblem)
When I scraped at the paint the "unprotected" areas around the emblem suffered very small scratches. So small there is no way I could get it in a photo.
You literally need to be 2 inches from the paint with something bright in the reflection to even see it.
I don't think it will be a difficult fix, I just don't want to use the wrong product and make it worse.
Old 07-25-2011, 12:56 PM
M.Scipione's Avatar
Rep:41
I'm thinking the "Meg's #3 Machine Glaze" will be sufficient for removing these tiny scratches?
I guess if not I can go a step higher, I just dont want to over do it...
http://www.amazon.com/Meguiars-3-Pro...1612695&sr=1-1
Old 07-25-2011, 02:35 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
Always use the least abrasive solution first. It might be trial and error the first time around. Your PC is your best friend. Good Luck.
Jay
PS--If it doesn't work you can always go to maybe 80 grit and work up from there----LOL--(just kidding)
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 07-25-2011, 08:44 PM
M.Scipione's Avatar
Rep:41
I got a bottle of #3 machine glaze and if that doesn't work I got scratchx 2.0.
From what I've seen the scratch x will handle it easily.
No thanks on the 80 grit.
Old 07-25-2011, 11:36 PM
Rep:276
Good luck, Megs #3 will probably not remove any scratches, but fill them. ScratchX2.0, SwirlX, Ultimate Polish, and Ultimate Compound are all better options. What pads do you have and what PC?
Old 07-25-2011, 11:39 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
start with the finest stuff and get rougher if necessary.
Old 07-26-2011, 12:41 PM
M.Scipione's Avatar
Rep:41
i have the 7424 PC and the 54745 polishing pad.
I also have Meguiars soft foam polishing and finishing pads with the velcro backing plate.
From the videos I saw on youtube I think scratchx2.0 will easily remove these scratches but I'll give the more gentle stuff a try first.
My main difficulty with this stuff is that there often isn't a very good indication of how aggressive the cutting of the product will be.
If it worked like sandpaper that would be ideal because 220 is obviously much gentler than 60.
Looking at bottles of polish I have no idea if "mirror glaze" is more or less abrasive than "machine glaze".
(turns out it's more abrasive btw, go figure)
Good that meg's is starting to put a scale on the bottle to give some indication of what I am about to do to my beloved truck.
Old 07-29-2011, 09:20 PM
HEMIRAM09's Avatar
HEMIRAM09 HEMIRAM09 is offline
Vehicle: 2009 Dodge Ram 4WD
Trim Level: Crew Cab SLT
Color: Inferno Red
Rep:43
HEMIRAM09 is on a distinguished road
I am new here so I'm not sure if I'm suppose to recommend products or not. If I'm not just let me know.
If you're looking for a simple polishing solution with a 110% money back guarantee I'd go with Adam's Polishes. I've been using their products for almost a year and have never looked back.
K&N CAI, Borla Turbo XL, Diablosport Trinity 93 Octane Tune, Color Matched Engine Cover...
Will these scratches come out? nikeman Dodge Ram Detailing and General Maintenance Forum 12 12-08-2013 04:17 PM
scratches and rust already? earlzie 2011 Dodge Ram Forum 14 05-08-2011 11:01 AM
A very tiny addition gregster 2010 Dodge Ram Forum 18 12-05-2010 12:03 PM
Removing scratches TobyGSD Washing & Waxing 4 03-28-2010 03:33 AM
scratches ram06bighorn Washing & Waxing 16 08-08-2009 02:14 AM
