Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 07-25-2011, 10:33 AM
dsander dsander is offline
Vehicle: 2004 Dodge Ram 1500
dsander is on a distinguished road
Default electric brake plug wiring help?
I have put a couple threads on here about this with no help yet. from what i have read that there should be a green wire that does not run all the way to the back of the truck to feed the electric brakes on the trailer. I found a green wire that go into a plug under the drivers side door but does not go to the back of the truck. there is also a red one that goes into that same plug and does not come out either. is that green wire the one i need to run back to the blue wire on my 7 pin plug? and what is the white wire with a red tracer that is already back there for? it comes out where the wiring harness splits for the tail lights.
Old 07-27-2011, 07:00 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top! I will also pass the thread along to one of our techies for you.
Old 07-28-2011, 12:15 AM
Thanks i really thought that someone on this forum would know how to hook this up. I am sure this is not the first ram that doesn't have all the wiring ran to the back. so far no luck.
Old 08-10-2011, 05:17 PM
08 BigHorn's Avatar
08 BigHorn 08 BigHorn is offline
Vehicle: 2008 Dodge Ram
Color: red
Rep:23
08 BigHorn is on a distinguished road
Check out these videos. It's extemely easy if you have factory tow package, just buy the adapter wire and plug from controller to the plug under dash. Or just do what they do on video.
Old 08-10-2011, 05:20 PM
And here's a link that might be helpful on tracing the wiring circuits as well:
http://www.ramforumz.com/showthread.php?t=39992
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
electric brake plug wiring help? dsander Towing 1 07-27-2011 06:48 PM
Electric brake controller wiring ddenton Electrical 1 05-24-2011 08:31 PM
Adding a electric brake controller dave k Electrical 3 08-06-2010 10:36 AM
Electric trailer brake plug Carvermitch Dodge Ram General Discussion 9 07-20-2010 07:44 AM
