Old 07-29-2011, 11:23 AM
ctbourg87's Avatar
ctbourg87 ctbourg87 is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
Rep:61
ctbourg87 will become famous soon enough
Originally Posted by ramrt1993 View Post
Sir, you have an amazing truck, I love it! great times by the way, I doubt I could get times that good in mine! Did you stall it? Also, traction control on or off? Tow/haul mode on or off?
Stalled it up to about 1500 (anything over that and i will spin off the line), traction control off and shifted it manually to catch 2nd prime
2010 Ram R/T= de-badged,mc 2/4 drop,dsp,aem cai,mufflex exhaust, edge 3000 stall, 4:10 gears
Old 07-29-2011, 12:02 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^question about that. Shifting manually alone doesn't let you catch second prime, you have to have tow/haul mode on, right?
Sean
Old 07-29-2011, 12:21 PM
ctbourg87's Avatar
Trim Level: R/T
Rep:61
no tow/haul mode. You hold the shifter all the way to left and let the truck shift out on its own and you will catch second prime.
Old 07-29-2011, 12:26 PM
snrusnak's Avatar
Rep:1385
That really confused me....then I realized you have a shifter in the center console, mine is on the column. So I have a button (+/-) on the shifter to up and downshift manually. I don't think mine catches 2nd prime without tow/haul on, and if I press it down to 1st, it won't shift out.
Sean
Old 07-29-2011, 02:30 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
Yep, I'm really confused now too..what do you mean hold the shifter all the way left? Wouldn't it be better to turn tow/haul on and let it shift itself?
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 07-29-2011, 02:41 PM
snrusnak's Avatar
Rep:1385
^ I'm assuming the console shifter has has a bump left downshift, bump right upshift function like many new vehicles have to manually shift. I also don't see how this would be different than tow/haul.
Sean
Old 07-29-2011, 03:00 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
Yep, you're right about bumping the shifter to shift, but that still doesn't explain how he held the shifter all the way left and let it shift by itself. If I did that, my truck would stay in 1st! I have to bump my shifter right every time I wanna go to a higher gear if I start in 1st.
Old 07-29-2011, 03:02 PM
snrusnak's Avatar
Rep:1385
I'm guessing that if you hold it left it won't let the engine over rev and will automatically shift. It's a safety feature. But does that mean if I leave mine in 1 and floor it then even if I don't manually press the button to change gears it will automatically upshift? Probably... But why do that, why not just put it in D?
Sean
Old 07-29-2011, 03:09 PM
ctbourg87's Avatar
Trim Level: R/T
Rep:61
yes, i have the center console shifter and when you hold it all the way to the left it will shift out on its own when you get to the shift point. If you just leave it in first and not hold it to the left the truck will stay in first gear. Tow haul mode did not help my times.
Old 07-29-2011, 03:12 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I would assume that instead of up shifting, it would cut off the fuel as if you hit the speed limiter. Not something I wanna try!
Drag Racing Tips dodgeman70592 Drag Racing Discussion 32 04-26-2014 10:33 PM
mygig HDD playlist and track playback davidreed Dodge Ram General Discussion 1 06-22-2012 01:06 PM
First track visit garner Dodge Ram R/T 22 09-02-2011 01:44 PM
upgraded track bar? SportHD Suspension 1 05-31-2011 02:58 PM
Big Yellows day at the track! Brian08 Dodge Ram Pictures - Photos 9 08-04-2009 05:59 PM
