Old 07-25-2011, 03:55 PM
Wiggitty's Avatar
Wiggitty Wiggitty is offline
Wiggitty is on a distinguished road
Default Looking to lower the rear end of my truck. Need help.
There seems to be no kits out there to simply lower the back end of my 4x2 truck. The goal I am trying to accomplish is to have my truck sit level. Typically this can be achieved with shackles, except they do not make them for my year. (2009) Can anyone help me out and give me some kind of option to make this happen?
-Wiggitty-
Old 07-25-2011, 04:09 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Your truck has a coil rear suspension, shackles are for leaf springs so is not applicable to your truck. There are some members on here that have cut their rear springs to lower the back 2" or so, and have had success with this. Others have bought kits from groundforce I believe, maybe others as well... I also know a company called ottomax makes kits (chevykllr used it). good luck.
Sean
Old 07-25-2011, 04:10 PM
snrusnak's Avatar
Rep:1385
Use the search box, type 'lowering rear" or something like that there's a few threads that should pop up with info...
Sean
Old 07-28-2011, 12:02 PM
rarichard's Avatar
rarichard rarichard is offline
Vehicle: 2010 HEMI Sport Crew Cab
Trim Level: SPORT
Rep:62
rarichard will become famous soon enough
look in the suspension section as I just did this days ago. The cheapest way out for a 2wd is to cut the coils, about 1 and 1/2, and use stock shocks. Very easy to do and since you have 2wd, most people wouldn't even think that it's custom.
Old 08-05-2011, 05:45 PM
TylerB's Avatar
TylerB TylerB is offline
Vehicle: 2011 Ram Express
Rep:25
TylerB is on a distinguished road
I've cut mine also. Took off 1-3/4 coils since I'm a reg. cab which is a tad bit lighter. The rear is about 1/2" higher now. No problems with bottoming out or towing. Only tools needed are a cut-off wheel, jack, and a pair of jack stands.
Old 08-05-2011, 05:52 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Easier, heat the coils with a torch when they are supporting the vehicle, just go slow and have some keep a measuring tape from the ground to the fender lip.
Old 08-05-2011, 08:30 PM
snrusnak's Avatar
Rep:1385
Please don't ever do this with a coil spring! It will ruin the spring and is very dangerous. You will end up with this:
If you want to lower the rear cheap and easy, cut the rear coils (at the top) about 1.5 coils, and don't heat them! Don't use anything that will get them hot, heat ruins springs. Use a sawzaw, cut off wheel, etc... and go slow, keep the springs cool.
Sean
Old 08-05-2011, 08:33 PM
Stainless's Avatar
Color: Bright white
Rep:13
I have never seen that happen, thats too much heat too fast in one area, thats why i said go slow, i have seen this done several times and it worked great. On the same side cutting coil springs is not recommended as springs In most cases are progressive, which means they have a different spring rate top to bottom, replacing the spring is the best thing to do in all cases.
Old 08-05-2011, 08:40 PM
snrusnak's Avatar
Rep:1385
The only way to properly heat and change the spring length would be to apply even heat slowly, which is impossible with a torch. If I were to do this I would clamp the spring to the desired length, and then put it in an oven. Actually I would never heat my springs....it really is very dangerous...Heating and bending metal makes it very weak and sometimes even worse, brittle. I had a friend with a F150 with twin I beam suspension and he heated the I beams and bent them for alignment after a lift (he was too cheap to buy a proper kit). I warned him and afterwards he raved about how great it worked and how much money he saved....months later one of the I beams broke in half from a bump in the road.
Sean
Old 08-05-2011, 08:53 PM
Stainless's Avatar
Color: Bright white
Rep:13
Bull shlit we did it on our SNOW PLOW at work, its just people that don't know what they are doing.....been there done it. I've done it dude.....best way replace your springs. Fords I beams are cast iron, are they not, you cannot heat and bend cast iron, only spring steel. Either way I don't rec both methods I just said it was a easy way.
Is my truck lifted? Need to replace rear shocks... carspaz Suspension 4 07-18-2011 09:59 PM
How long have you been waiting? Bert66 2011 Dodge Ram Forum 62 06-07-2011 04:46 PM
I want to lower the rear only durgam605 Suspension 1 05-24-2011 01:50 AM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 01:13 AM
Dirt Builds Up in the Bed of My Truck Rocky Harbour 2010 Dodge Ram Forum 4 05-27-2010 12:23 PM
