Old 07-26-2011, 11:01 AM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:54
Ramathorne will become famous soon enough
Default Jet 180 Degree Stat
Is this the correct stat for my 2010 Ram?
http://moesperformance.com/index.php...oducts_id=9078
Looked it up and some sellers state 2003-2008 while others also include the 2009+ HEMI's with same PN
Old 07-26-2011, 11:16 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
If it works in the third gen, it works in the 4th! I have living proof of that with my AutoZone 180 T-stat
Old 07-26-2011, 11:18 AM
Color: Mineral Gray
Rep:54
Cool
Thanks
I shall order it this afternoon!
Old 07-26-2011, 03:52 PM
mtbiker033's Avatar
mtbiker033 mtbiker033 is offline
Rep:25
mtbiker033 is on a distinguished road
I had heard about the 180deg thermostats and want to get one myself but can someone explain how this helps?
2010 Dodge Ram 1500 Quad Cab // K&N Drop in // Tint (20% rear / 35% front)
Old 07-26-2011, 05:02 PM
Schnitzer21's Avatar
Schnitzer21 Schnitzer21 is offline
Color: Brilliant Black Pearl Coat
Rep:93
Schnitzer21 will become famous soon enough
I would be interested in someone explaining this as well, other than the obvious that the engine would run cooler. Would the AC be colder? Would the heat in the winter time not be as warm? What really are the benefits to doing this mod?
Dodge Molded Splashguards, Dodge Slush Mats, DeeZee Bed Mat, "Herculined" inside Toolbox with dual LED Lightbars, Diablosport Predator (U7137), Hell Bent Steel 2.5" Leveling Kit, Mopar Chrome Tubular Side Steps, Billet Technology Oil Catch Can, JET 180 T-Stat, 18" Magnaflow Muffler with Y-Pipe.
Old 07-26-2011, 05:10 PM
916Timmy's Avatar
Rep:1443
It keeps the motor from heatsoak, which basically means the motor makes less power the hotter it gets. A/C and heat are not affected by the change.
Old 07-26-2011, 05:35 PM
Rep:93
How hard of an install is this? I wouldn't have to drain all of the coolant in order to install the thermostat would I? Does anyone have a tutorial written up? Thanks!
Old 07-26-2011, 08:28 PM
916Timmy's Avatar
Rep:1443
Here's mine!
http://ramforumz.com/showthread.php?...=autozone+4128
Old 07-27-2011, 09:57 PM
Mohawk Theriot Mohawk Theriot is offline
Vehicle: 2013 Ram 1500 4x4
Mohawk Theriot is on a distinguished road
Will changing thermostat mess with warranty?
Old 07-27-2011, 10:14 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
No, changing your TStat wont. Hell, they probably would never even know honestly even if they broke into your motor.
2015 Camaro 2SS/RS/1LE
jet 180 stat Parry33 Heating & Cooling 5 04-10-2011 12:18 PM
2010 4.7L 180 degree thermostat? ssgthurst 2010 Dodge Ram Forum 4 03-03-2011 02:14 PM
1 degree colder? Torq89 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 11-09-2010 11:03 AM
180 degree stat part numbers jasondevore Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 09-26-2010 12:52 PM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
