Front is Lower than rear, Also hearing Ratteling noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-26-2011, 11:39 AM
JtmDevilDog's Avatar
JtmDevilDog JtmDevilDog is offline
Vehicle: 05 Ram 1500 Quad Cab Daytona
Trim Level: Daytona
JtmDevilDog is on a distinguished road
Default Front is Lower than rear, Also hearing Ratteling noise
Ok so I'm lost on what this could be. I have a 2007 Ram 1500 Quad Cab 4x2. I have a heavy duty replacement bumper on the front. I added a leveling kit to the front, but didn't replace the shocks, cause I was told it didn't need it. Its been about a yr now. But the front is now lower than the rear, as if i lowered the front like 3 inches. I'm also hearing a rattling noise. You can feel and hear it under your feet while you are driving, and can only feel and hear it when you hit any kind of bumps. I don't have my lift any more nor my tools. I have looked at it but haven't taken anything apart just yet. Does anyone have any ideas or what to check for fist???
Old 07-28-2011, 03:38 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-28-2011, 04:14 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I would try replacing the shocks. Leveling kits put alot of stress on the stock length shock because it max's out the travel ontop of the extra weight of your bumper. Everytime you hit a good bump you bottom out the shock basically.
I ran stock length shocks on a 2500 with a leveling kit for a year and just replaced them with +2" shocks about a month ago. The stock shocks were fine, the tubes clacked and rattled when you hit bumps, but the truck rides much better now.
I'm not sure if the shocks are your whole problem but it cant hurt. I think you can actually put a stock 2500 shock on yours and that will give you the +2" you need
Old 07-29-2011, 12:27 PM
Trim Level: Daytona
Thanks for the replys
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
04 ram Hd 2500 what tire size with 2''kit front & rear? gear head Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 02-03-2012 11:08 AM
Just Got My Build Sheet highlandchef 2009 Dodge Ram Forum 11 05-24-2011 05:12 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 10:48 PM
2009 Front End Noise ripp23 2009 Dodge Ram Forum 8 03-20-2010 06:21 PM
