Old 07-26-2011, 04:34 PM
MIgY347's Avatar
MIgY347 MIgY347 is offline
MIgY347 is on a distinguished road
Exclamation Check engine and traction control turned on?
When I was driving to work this morning I noticed that the check engine and traction control turned. Any one have similar problem
Old 07-26-2011, 04:48 PM
I've heard of this happening randomly to other folks.
If you do an ignition cycle (On/Off/On) it should go away.
If not, disconnect your negative battery cable for about 30 minutes, plug it back in and start the truck. If it's a persistent problem, and either of those items are blinking, get thee to a dealer.
Old 07-26-2011, 09:35 PM
MIgY347's Avatar
i tried turning it off and on and it didnt work. I called the dealership and made an appointment. After i got off of work i tried to turn her on and she didnt turn on the first time.
check engine light, problems, traction control
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Traction control? gabe20 Dodge Ram General Discussion 21 05-14-2013 09:46 PM
check engine light jerzy1283 2010 Dodge Ram Forum 10 10-13-2010 02:34 AM
