Old 07-26-2011, 06:36 PM
jaxn jaxn is offline
Vehicle: 2014 Dodge Ram 1500 Limited
jaxn is on a distinguished road
Default Nerf bars/tube steps
Hi everyone. I just bought a new 2011 Ram 1500 Sport. Needless to say my mods list is growing more as I read everyone's posts. One of the first things I need because I am short and it helps keep mud off is some bars. I am looking at either nerf bars or some tube steps. I know I will get a lot of "it's whatever your preference is" feedback and I understand that. I was looking for more of praise for a good product you have or bad experiences you have had. For instance on my old 2009 Ram 1500 I had the Mopar tube steps. Did they look good yes, but they were chromed aluminum and showing rust spots. So I am looking for SS with a lifetime warranty and would like your feedback on what has or hasn't worked good for you.
Thanks for all the help and great website!!
Cheers,
Jaxn
Old 07-26-2011, 09:53 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I really like this style. http://4wheelonline.com/Go_Rhino_Dom....170613.631931
I'm not a big fan of oval/tubular steps.
Dillon-aka, The Little Kid
Old 07-26-2011, 10:16 PM
Don't forget to look at powdercoated nerf or step bars. They will hold up better.
Old 07-26-2011, 10:29 PM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
I had the Westin Chrom plated SS on my 04 QC and they held up well, Since I didnt have issues I stuck with Westin on my crew cab. I had to go with the polished SS this time because I wanted the ovals. I like them because I have read some will flex or not feel sturdy and the westins bolt up good and no flexing even with my 265 body stepping on them!
Old 07-28-2011, 09:57 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
I had a set of Westins on mine that weren't SS and rusted right on through, so definitely get SS or Powdercoated with some good end caps to help keep water. I really like the steps that Geauxhunting posted, I'm not a huge fan of the oval or tube steps.
Old 07-28-2011, 04:20 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I bought the go rhino 2 step bars for my truck, they are powdercoated black with a warranty (although can't remember how long). I think the chrome ones have a longer warranty. They are really nice, durable, the ends are welded closed so no water can get in and rust. The powdercoating is also very good. I'm not a fan of the oval steps either. In my opinion I bought a better built, better looking step for less money...
Sean
Old 07-28-2011, 07:00 PM
unrealtrip's Avatar
unrealtrip unrealtrip is offline
Vehicle: 2008 Ram Big Horn 4x4
Rep:27
unrealtrip is on a distinguished road
I went with the OEM aluminum powdercoated black ones for a few reasons (added them recently). I somewhat like the Go Rhino ones, but I don't like that there are only narrow little spots where you can step, vs a tube that has a lot of footing. Also, the oem tube is tight up to the body, vs the aftermarket ones that stick way out. I went with aluminum and I'm glad I did, for their size they have almost no weight, yet there are quite stiff and hold a lot of weight, pretty amazing really.
I've got a shotgun a rifle and a four wheel drive...
Old 07-28-2011, 08:27 PM
t05ks t05ks is offline
Vehicle: 2011 Dodge Ram 2500
Trim Level: SLT Bighorn
Color: Deep Cherry
t05ks is on a distinguished road
If you plan on keeping the ram for a long time then it may worth considering a good stainless steel brand. Chrome plated just doesn't hold up well in the long run. Another thing to consider is that with nerf bars there is very little rock chip protection for the rocker panels. On our 96 ram I installed fiberglass running boards which also wrap around the wheel wells. There is no paint loss or rust due to rocks. The running boards also help prevent road salt from getting into the lower door creases (if thats a concern). On our 2011 Ram I had the dealer remove the factory ram nerf bars and install stainless steel luvern running boards. I wanted the max protection for the truck. Food for thought
Old 07-29-2011, 05:20 PM
Grumpy Grumpy is offline
Rep:13
Grumpy is on a distinguished road
I doubt you had chromed aluminum, you probably had chrome on mild steel. Alumimum can rust, but it's white, not brown.
You have your choice of mild steel, stainless steel, or aluminum. Aluminum steps are fairly rare, the most common are mild and stainless.
If you want the "chrome" look, you can buy polished stainless steel, chrome on mild steel, or chrome on stainless steel. Chrome on stainless steel is rare, but Westin makes them and they are expensive. The most common is polished stainless steel. Even if you buy polished stainless steel, the mounting brackets will be galvanized mild steel. The ONLY company that makes 100% stainless steel including mounting brackets, nuts, bolts, and washers is Nasta.
If you want black powdercoated steps, you have a choice of black powdercoated mild steel (most common) or black powdercoated stainless steel. Not may companies make black powdercoated stainless, but Westin does and yes, they are expensive. The problem with black powdercoated mild steel is that if you chip the powdercoating, the rust process will begin.
Old 08-06-2011, 12:16 AM
Thanks everyone for the feedback. Still looking but I appreciate all the help. Debating the Westin Ovals or Rhino 4 or 6 inch bars.
300MAG do you have any pics of your Westin Ovals?
Grumpy-They might not have been chromed aluminum. I was just going off the description of the Mopar accessories website, as they said they were. They were good and sturdy but showed rust spots.
side steps nerf bars etc..... Alberto22 2011 Dodge Ram Forum 8 04-24-2011 04:45 PM
Nerf bar steps question thewagon 2010 Dodge Ram Forum 23 02-01-2011 10:44 AM
Installed Go Rhino Nerf Steps bucholj 2011 Dodge Ram Forum 11 01-26-2011 09:44 PM
Nerf Steps PSU Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 06-20-2010 11:14 AM
Nerf bars, Side Steps? PICS? HORNYHEMI Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 13 04-15-2010 05:56 PM
