Vibration when towing... a small jon boat? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 07-27-2011, 12:28 PM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Default Vibration when towing... a small jon boat?
Havent been on here a while, good to be back.
I bought a 14' jon boat this past spring and when towing the 1,000 lb. boat & trialer I get a strong in and out vibration at highway speeds 60 mph and over, other than that I dont even know its behind me. This is the first thing I have towed with my truck, but I have loaded the crap out of the bed and never had any vibration issues. My truck is completely stock and I had the driveshaft rebalanced about a year ago after my mechanic noticed a missing weight, not sure I noticed it or it made any differance though he just happened to notice it replacing my diff fluid and checking u-joints.
I would think if it were the weight of the boat causing the driveshaft angles to be out it would have vibrated whith a fully loaded bed too, Ive had it squatting pretty low but not overkill.
Not sure if the trailer tires (tubeless) have been or need balancing or not. Seems to me this might be the issue but I wanted to check with the forum before I start shelling out cash.
Thanks
Old 07-27-2011, 12:37 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
My only thought when I read the title was trailer tires out of balance...
Sean
Old 07-27-2011, 02:30 PM
Kens04's Avatar
Rep:48
Thats what I was leaning toward too, I am just suprised that so much vibration can be transfered from the trialer to my steering wheel and dash.
Old 07-27-2011, 02:50 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
If you know someone else with a trailer, hook up and pull it a few miles. It might help you narrow down the problem. I can see bad tires causing vibrations in your truck, but I would expect you to feel it more in your seat than your steering wheel.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 07-27-2011, 03:18 PM
Yeah...I suspect the trailer tires & wheels.
Vibration when towing Ramster10 Towing 13 12-05-2013 05:29 PM
Vibration While Towing in Heat Jmccar 5.7L (345 cu in) HEMI V8 Specific Topics 2 07-04-2011 12:34 AM
First time towing my boat tcryfp 2011 Dodge Ram Forum 8 05-10-2011 11:57 PM
Towing a Boat Blue Bear Towing 1 03-14-2011 09:30 AM
Boat Towing.... brolland 2010 Dodge Ram Forum 3 04-15-2010 09:48 PM
