Old 07-29-2011, 02:12 PM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
Originally Posted by riggz View Post
Where do you see that it shows as standard equipment on the sport trim?
That wouldn't make much sense to not be able to arm it unless the door was open. Where do you see this in the manual? I am not able to find any reference to this.
The sales brochure on ram trucks website
Old 07-29-2011, 02:18 PM
Jixer's Avatar
Jixer Jixer is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn quad cab
Rep:112
Jixer will become famous soon enoughJixer will become famous soon enough
Page 18 and 19 on an online owner's manual. Hope this helps ya. First off, I guess be sure your vehicle is equipped with the vehicle security alarm.
13. Vehicle Security Light — If Equipped
This light will flash at a fast rate for approximately
15 seconds, when the vehicle security
alarm is arming, and then will flash slowly
until the vehicle is disarmed
VEHICLE SECURITY ALARM — IF EQUIPPED
The Vehicle Security Alarm monitors the vehicle doors
and ignition for unauthorized operation. When the Vehicle
Security Alarm is activated, interior switches for
door locks are disabled. The system provides both audible
and visible signals, for the first three minutes the
horn will sound and the headlights, park lamps and/or
turn signals will flash and Vehicle Security Light will
flash repeatedly. For an additional 15 minutes only, the
headlights, park lamps and/or turn signals and Vehicle
Security Light will flash. Use of the Sentry Key
 will
disable the alarm.
Rearming Of The System
The Vehicle Security Alarm will rearm itself after the 15
additional minutes of headlights and Vehicle Security
Light flashing, if the system has not been disabled. If the
condition which initiated the alarm is still present, the
system will ignore that condition and monitor the remaining
doors and ignition.
To Arm The System
The Vehicle Security Alarm will set when you use the
power door locks, or use the Remote Keyless Entry (RKE)
transmitter to lock the doors. After all the doors are
locked and closed, the Vehicle Security Light in the
instrument panel cluster will flash rapidly for about
16 seconds to indicate that the alarm is being set. After
the alarm is set, the Vehicle Security Light will flash at a
slower rate to indicate that the system is armed
NOTE:
If the Vehicle Security Light stays on continuously
during vehicle operation, have the system checked
by an authorized dealer.
To Disarm The System
Use the RKE transmitter to unlock the door. If something
has triggered the system in your absence, the horn will
sound three times when you unlock the doors and the
Vehicle Security Light will flash for 30 seconds. Check the
vehicle for tampering.
The Vehicle Security Alarm will also disarm if the vehicle
is started with a programmed Sentry Key
. To exit the
alarming mode, press the RKE transmitter UNLOCK
button, or start the vehicle with a programmed Sentry
Key
The Vehicle Security Alarm is designed to protect your
vehicle; however, you can create conditions where the
system will give you a false alarm. If one of the previously
described arming sequences has occurred, the
Vehicle Security Alarm will arm regardless of whether
you are in the vehicle or not. If you remain in the vehicle
and open a door, the alarm will sound. If this occurs,
disarm the Vehicle Security Alarm.
Dave
K&N series 63 CAI - 22" Magnaflow muffler - MyGiG Lockpick V.4 - Rhino spray in bedliner - Truxedo LoPro tonneau cover - front and rear view cameras - side steps - tow hooks - skid plates - slush mats
Old 07-29-2011, 02:29 PM
Jixer's Avatar
Rep:112
Here is the link. Just select your model year and vehicle and then click download. It is a 6mb file. http://www.dodge.com/en/owners/manuals/
Dave
Old 07-29-2011, 06:21 PM
TerryH's Avatar
TerryH TerryH is offline
Vehicle: 2011 Ram 1500 Sport
Color: Mineral Gray
Rep:103
TerryH will become famous soon enoughTerryH will become famous soon enough
Didn't make much sense to me either but I didn't engineer it.
2011 Ram User Guide Page 9.......
THEFT ALARM
To Arm:
Press the Key Fob LOCK button or the power door lock switch while the door is open.
To Disarm:
Press the Key Fob UNLOCK button and turn the ignition to the ON/RUN position.
This is the same way it works on our 2011 Charger R/T as well.
HE > me
Old 07-29-2011, 11:48 PM
riggz riggz is offline
Vehicle: 2011 Dodge Ram 1500
riggz is on a distinguished road
THEFT ALARM
To Arm:
To Disarm:
Ah! I see what they are saying... to ARM it you can either use the key fob lock button OR the button on the door switch while the door is open. That way it will arm when you close the door. If you lock the door from the door switch with the door closed, it assumes you are in the vehicle and will not arm the system. That way you can arm it without having the FOB (if you just had a regular key).
Old 07-30-2011, 12:13 AM
I looked at the brochure. It says it's a standard option on the Laramie but not on the Sport.
Old 07-30-2011, 12:36 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
No flashy light = No factory alarm.
brad
Interested in one of my mods?
Old 07-30-2011, 01:03 AM
To those with the Sport trim and factory alarm: was it listed on your sticker and do you also have the factory remote start?
Old 07-30-2011, 01:23 AM
brad12kx's Avatar
Rep:2581
Mine was part of the 'Remote Start and Security Group'.
brad
Old 07-30-2011, 10:03 AM
Yeah that's what I figured. I guess what I'm trying to determine is if I get the factory remote start kit does that include the security feature or is that an extra part?
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 12:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
04 ram 1500 5.7 security light flash no start nmdodge Electrical 7 09-15-2010 01:50 PM
2007 Dodge Ram 1500 Security Light Sam Newbie Checkin! 10 01-19-2010 07:56 PM
