Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
tonneaucovered.com
Old 07-27-2011, 09:34 PM
warrenc warrenc is offline
Vehicle: 1998 dodge ram 1500 sport 1cab
warrenc is on a distinguished road
Default leake from front axel
i have a 1998 dodge ram sport 4wd and there is something thats mounted on the axel on the right hand side and it is leaking gear oil pretty bad what is this think called its small and it has a small tray or skid plate undear neath it with wires going to it and i want to fix the leak please help
Old 07-27-2011, 11:49 PM
BossHog9110 BossHog9110 is offline
Vehicle: 1994 Dodge Ram
BossHog9110 is on a distinguished road
that is the 4wd actuator, its a vacuum operated fork that connects the axle shafts when you put the transfer case in 4wd, those wires are what turn your 4wd indicator light on, for some reason those 4 bolts on it come loose, also it is exposed to all kinds of shit, you may need a new gasket or put some sylicone gasket maker on it, and tighten those bolts, i think they are 3/8 or 10mm
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
spicer 60 front and rear axel question pirayaman 5.9L V8 Specific Topics 1 03-11-2012 11:34 PM
replacing left front axel seal Ram98 Suspension 2 07-09-2011 10:47 AM
Front Axel U-Joints MaddogGM Suspension 3 05-01-2011 10:04 AM
replace front axel universal mordodge Newbie Checkin! 12 09-16-2010 06:35 PM
