Old 06-21-2011, 08:01 PM
jlanne1 jlanne1 is offline
Vehicle: 2011 Dodge Ram
jlanne1 is on a distinguished road
Default Brake Pedal rattle/Excessive play
I have a 2011 Ram slt. I recently noticed that everytime a hit a sharp bump i was hearing a rattle. I thought it was a loose front end part or something. but one day i put my foot on the brake pedal and realized thats where the noise was coming from. it seem to have very excessive side to side movement, and now everytime i hit a bigger bump i notice it. I brought it to the dealer and they said that all the 1/2 tons on the new lot are the same so they couldnt do anything for me.. Anyone else have this issue it bugs the hell out of me now..
Old 06-22-2011, 01:46 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Yea stop going to the dealer for advice, they know nothing about what they try to fix. They're only good for taking care of the stupid recalls.
Anyway's try to put some caliper lube on all contact parts of the caliper and pad except for the lines and pads braking surface the brake lining. Anyways try that and don't over tighten anything just torque to spec and be sure to seat the bearing properly. Try this for now.
Old 06-22-2011, 01:55 PM
Rep:2657
A service writer at the dealership is taught rule#1
tell the customer that all vehicles of your year do that they try to baffle you with B.S. hoping that you let it slide
your response should be, lets take a ride in another one just like it & see if your right
Old 06-22-2011, 04:14 PM
ramvan2500's Avatar
Rep:128
The point of a dealership is not to fix cars but to sell them and thats about it. I went to my local dealer where I get hard to find parts and I talked to the parts manager who was also a service manager I believe not sure on that though and he even told me that the mechanics don't really torque anything they just know when it's tight enough and I'm thinking god forbid you needed some serious engine and transmission work. Point is they don't really know what they're doing, they don't care if it's a safe repair, they care less they have their insurance and bs to protect them. Anyway's no brakes should normally sound and feel like crap. If that was true there should be a recall on it.
Old 06-22-2011, 04:32 PM
Seems to me that the dealer should (1) investigate the complaint, (2) verify the condition, and, (3) resolve the issue.
So tell them you don't feel safe driving the truck with a brake pedal that may be defective and that you would like them to spend a little more time working on the issue.
Also, you could look underneath and see where the wobble originates. If it's a pin or bolt that is undersized or loose, show them. Or fix it yourself.
Old 06-22-2011, 09:18 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Otterdriver has a spectacular aura aboutOtterdriver has a spectacular aura about
My truck does the exact same thing, it's pretty cheap feeling, I posted a while back on this issue, I just haven't had the time to fix it. I automatically hook my left foot behind the brake pedal riding over bumps, kinda shitty for a new vehicle.
Old 06-23-2011, 07:18 PM
estoltz estoltz is offline
Vehicle: 2011 Dodge Ram 1500 5.7 4x4
estoltz is on a distinguished road
Mine is doing the same. From what I can tell I am getting the rattle from the panel under the steering column. If I keep my shin up against it the rattle stops. I'm going to the dealership tomorrow to handle that, a dent (bought the dent package) and some noise in the rear end. (no not the taco bell noises). We will see what they say. I've had really good results from the parts department but then being a part of a large Modern Mopar Club here in DC tends to have that affect. We draw over 100 show cars/trucks on short notice.
Old 06-24-2011, 12:55 AM
yes it is shitty for a new truck! just makes me hate it actually. let me kno what they say about yours and if they fix it or not.
Old 08-02-2011, 11:19 PM
TacoKraut TacoKraut is offline
Vehicle: 2011 Doge Ram 1500
TacoKraut is on a distinguished road
Hello, new member here. I have this pedal rattle as well. I took it to the dealer and asked them to investigate the suspension. I told them that on a sharp bump in the road the I got a suspension rattle. They claimed they could not reproduce the problem. I finally spend some time under the truck and found 1) the emergency brake cable hits a weight mounted outside the frame and cause a lot of noise under the truck. I temporarily wrapped the cable with some rubber tape until I get it back to the dealer. This helped a lot. 2) I did find that the brake pedal has a lot of play and rattles as described above. I do not have a fix for this, but did find that there is a drop of light weight oil coming off a solenoid mounted to the brake pedal arm. Not sure where it is truly coming from. I plan to get it into the dealer real soon and will let you all know what they do/don't do.
Brake pedal is stiff snojet 2010 Dodge Ram Forum 1 03-16-2011 10:43 AM
Squeaky Brake Pedal? Bigman 2010 Dodge Ram Forum 6 10-12-2010 07:16 PM
E Brake Pedal jroc92980 Newbie Checkin! 10 09-28-2010 01:17 AM
Strange noise/vibration on brake pedal sanababit 2010 Dodge Ram Forum 3 01-17-2010 01:38 AM
Hard brake pedal Donovan Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 01-11-2010 11:56 AM
