Old 02-10-2013, 10:49 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Originally Posted by Presleysdad View Post
Talked to a local 4x4 shop today and was told that if I kept the factory Off Road wheels that I could not put 35" tires on without them rubbing. No I'm really confused and in need of some good information
Probably because of the backspacing. You'll rub on the control arm. I think you can run them with 35's with a 1/4 inch spacer. Or you can get new rims.
Old 02-24-2013, 06:29 PM
in4aride in4aride is offline
Vehicle: 1998 Ram 1500
in4aride is on a distinguished road
My stock 98 1500 running 315/75/16 (35's) Nitto Terra grapplers. Stock rims and it rubs on control arm at full lock but that is it.......
Still have the sway bars connected FWIW
When in dount throttle out, so hold it wide and let it slide
Old 09-15-2013, 04:31 PM
Bigred74's Avatar
Bigred74 Bigred74 is offline
Vehicle: 1999 Dodge Ram 1500
Rep:258
Bigred74 is a jewel in the roughBigred74 is a jewel in the roughBigred74 is a jewel in the rough
Default Good place to buy tires
hey guys if you are wanting a place to buy tires i just bought some from discounttiredirect.com. ordered a rim and tire combo so they shipped to my house free of charge already mounted and balanced! 17'' eagle alloy rims with 315/70/17 nitto trail grapplers. most sites wanted $2,000+ but got them on that site for $1400 so thought that was a steal plus they offer one year financing which was a big help since im in college lol
also new rims help alot on rubbing... my 285's on stock rims rubbed and my new 315's on the new rims dont rub at all! hope this helps some of you guys! happy truckin!!
*Bedliner paint job, leveling kit, 3'' body lift, 17'' eagle alloy rims series 197, 315/70/17 Nitto Trail Grappler M/T tires, S&B cold air intake, 52mm ported and bored throttle body, Superchips 3865 programmer
Old 09-24-2013, 04:30 PM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
^Back in 2006 I swapped out my ORE 17" rims for Helo Maxx 6 17" rims (BS = 4.5") and 33" Dick Cepek FC 2 tires. Only a kissing on the inner fender well plastic at partial lock. Mounted, installed, lifetime balance/rotation/repairs from Discount Tire = $1486. Lasted for 55K miles
Here is only picture I could with them at the moment.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 12-08-2014, 02:39 AM
doddgedaniel doddgedaniel is offline
Vehicle: 2000 dodge ram
Color: grey
doddgedaniel is on a distinguished road
I have a 2000 Dodge Ram 2500 with a 3.5" leveling kit. It clears 35x12.5 toyo mud terrains just fine. I actually had then on there before the leveling kit and I had no problems. At first it would rub on the control arms on sharp turns. I put a quarter inch wheel spacers and Its fine now.
Also, my dads running 37x13.5 toyos on his 06' 3500 cummins, stock height, stock rims, only has a quarter inch wheel spacer on it. We cut the fenders back near the door a little bit and they fit. They rub on the control arms a bit on sharp turns, but hell they're 37's on a stock height truck.
Old 01-03-2015, 07:12 PM
RowdyRam's Avatar
RowdyRam RowdyRam is offline
Vehicle: 1997 Dodge Ram 2500
Trim Level: Slt
Color: Brown/silver
Rep:18
RowdyRam is on a distinguished road
This has been discussed to death, but with 4 inches of lift 37s clear on my truck only rubbing on my mudflaps, nothin else
97 2500 5.9, 4inch lift 37x12.50x17 cooper stt
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 91 05-06-2015 04:41 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 10:25 PM
Tire Clearance weeseekase 2010 Dodge Ram Forum 4 02-14-2010 12:17 PM
