Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-28-2011, 07:17 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Default Check Valves
Truck is a 1996 Dodge Ram with the V6. The A/C blows out of the panel vents until I step on the gas, then it reverts to the defrost vents. I'm guessing that the vacuum lines coming from the manifold with the check valves are bad. It looks like there are several check valves and vacuum "t's" coming off the manifold vacuum hose. Can someone send me a picture of their vacuum check valves and routing so I can make sure I get the correct replacements. On my truck they are located on the passenger side of the firewall.
Thank ya
Old 07-31-2011, 09:47 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Thank ya
I can tell you that it is certainly a vacuum leak but to be 100% sure just do a quick vacuum test it would be wise anyways cause then you can find out if their is any engine problems not that I am saying their is but you can kill two birds with one stone. Anyway's I don't think it would be check valve I don't remember any magnum's coming with check valves the vacuum leak you might be having it probably under the dash or by the T'S that is in front of the engine hidden behind the alternator, I don't have any pictures to show but to make it cool just check every vacuum line you can find, don't confuse the EVAP with the vacuum lines.
Old 07-31-2011, 11:08 PM
Do you know what the vacuum readings should be?
I thought there were several vacuum check valves, but I'm probably wrong.
Old 07-31-2011, 11:11 PM
ramvan2500's Avatar
Rep:128
For a normal engine meaning no leaks it should be between 17-22 In Hg. I do know you should expect the needle to be at around 20. I don't believe their is any check valves, the only thing that checks for vacuum or pressure is the MAP sensor, everything else old fashion.
Old 08-03-2011, 01:51 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I had the same problem but it wasnt a vacumm related issue, mine was the little plastic thing that the accutator arm goes to broke so i drilled it out and installed a bolt/nut. but the silver canister next to the gas pedal is what controls that flap for the dash/defrost flap, check to see if that vac line is loose/cut/broke going to the back of that canister. It is just above the gas pedal towards the right side when you look up under the dash. Here is a picture of it.
Mike
Old 08-03-2011, 10:43 AM
Where was this actuator arm of yours that broke?
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 04:59 PM
Check Engine Light and RPM trouble mclovin7794 4.7L PowerTech V8 Specific Topics 6 06-23-2011 03:44 PM
check guages light on DODGEARCHER Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 06-22-2011 11:21 PM
Had my first Check Engine light ELFATKAT 2011 Dodge Ram Forum 1 06-07-2011 02:04 PM
Check Engine Light was on for the pass month erone 2010 Dodge Ram Forum 15 03-24-2011 11:56 AM
