Old 07-28-2011, 10:28 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
Default I Need Help With Traction!
Every freakin' time I take off from a dead stop or a 5-15 roll in my wonderful truck, I spin the tires! Even if I don't stall it. Is there any way I can launch my truck without shredding my tires? I'm still running my stock tires, I have 4,300 miles on my truck. They're inflated to 40 psi. It seems like since I added the intake and exhaust and let the truck break in, it spins even more now.
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 07-28-2011, 10:37 PM
Lower the tire pressure a bit. Lighten up on the right foot pressure.
If ya want to launch without spinning, at the dragstrip you do a burn out.
On the street, ya can do that but it's not recommended. Police hate that stuff...LOL
What kind of tires do you have now?
I have the same problem with my SRT.
Old 07-28-2011, 10:43 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
The main reason I don't wanna spin is to keep my tires new...burnouts aren't gonna help
I have the stock Good-for-a-years I think they're 285/45/22.
Old 07-28-2011, 10:52 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Gently lay in the pedal until you are able to use cruise control.
Old 07-28-2011, 11:01 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
yeah...great idea, I'm sure I'll win a lot of street races that way!
Old 07-28-2011, 11:55 PM
Well, I'd check the wear rating on your tires. The higher the number, the harder the rubber and they are easier to spin.
A stickier tire would help.
If you are gonna street race, you are gonna spin them Goodyears. I could barely keep the Goodyear F1's under my SRT from cooking off, even with a less than full throttle blast. Even at freeway speeds, if I buried the throttle, they'd go up in smoke. Made for some funny times when folks saw me open it up from 65 mph and it started boiling the tires.
I now have a stickier set of Toyos on that car and they don't break loose unless I want them to...which is often...
Old 07-28-2011, 11:57 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
My tires are at 35 psi...not sure what the 22's would need...but my truck is on 20's and a tad bit heavier!
Old 07-29-2011, 12:01 AM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I had no idea wear ratings even existed! So, I obviously don't know how to check them. But tomorrow morning I'll look at my tires and see what I can find. I wish I could make mine break loose at freeway speeds... I'm thinking I might go to 35 psi, I just don't wanna lose any MPGs.
Old 07-29-2011, 12:35 AM
They are on the sidewall of your tires. Also known as a durometer rating, they can range from 200 (sticky) to over 400 (hard and slippery).
Here's some info if you care to read up on it:
http://www.tirerack.com/tires/tirete....jsp?techid=48
Old 07-29-2011, 12:47 AM
Color: Satin Orange
Rep:597
Thought you were referring to general street manners not hole shot street racing.
Get a softer tread tire or run drag radials full time.
hemi, launching, ram rt, tires, traction
Traction question/ plz help HOTHEAD 2009 Dodge Ram Forum 12 03-17-2011 04:00 AM
Esp and traction control problem daversv 2010 Dodge Ram Forum 12 02-03-2011 03:23 PM
Traction control on or off when stuck in snow? steve57 2010 Dodge Ram Forum 6 12-14-2010 01:14 PM
2005 Ram Have Traction control? Ruffian11 Dodge Ram General Discussion 3 03-07-2010 06:09 PM
Traction Bars 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 02-19-2009 12:42 PM
