Old 07-28-2011, 10:17 PM
Jebster's Avatar
Jebster Jebster is offline
Vehicle: 2011 Dodge Ram
Color: Fame Red!!!
Jebster is on a distinguished road
Default Rhino Lining problem
I had a Rhino Liner sprayed in by Ziebart on Monday. Was putting my tonneau cover on and was in the bed of the truck and could see light coming through the bed. There is a seam that runs the entire length of the bed next to the wheel wells. This is where I could see the light. It wasn't the entire length of the seam but was on the other side as well. Does anyone know if they run a tool down this seam to make sure the lining gets down into it? That is the only explanation I can think of. When they ran something down the seam, it cut the bed. If the bed was cracked before application, the lining would have covered it up.
Thoughts?
Old 07-28-2011, 10:39 PM
hmmm...I know it goes on warm but it's not that warm enough to split metal!
That's a very weird issue.
Old 07-29-2011, 01:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I agree if it was cracked before it would have been covered. Could have them just spray more over it to cover it up. I can't believe ziebart is still in business haha, that's an old name you don't hear very often! My dad gave me his 1981 F100 that was "ziebarted" in 1981 when he bought it new, it has little yellow disks glued inside the door jamb that say "ziebart lifetime rust warranty" or something like that. Needless to say, it didn't last a lifetime without rusting....but probably did better than from the factory (pittsburgh vehicle driven in snow/salt). We replaced the fenders and hood in the late 90's, now the bed, gate, doors, and maybe cab (at least corners) will need replacing... sorry to get off topic, but brought up a memory lol.
Sean
Old 07-29-2011, 04:57 PM
Grumpy Grumpy is offline
Rep:13
Grumpy is on a distinguished road
Your situation tells me they sprayed your bedliner way to thin. If the bed did have a separation, you would think a bedliner of proper thickness would fill it in.
Why he heck did you get Rhino anyway?
Old 07-29-2011, 06:24 PM
snrusnak's Avatar
Rep:1385
What's wrong with Rhino?
Sean
Old 07-30-2011, 01:27 PM
Rep:13
Older technology, not as strong as other brands. For example, according to the technical data sheets, LINE-X has a 31% higher tear strength, a 53% higher tensile strength, and a 45 degree higher temperature tolerance. In addition, Rhino does not have a product like LINE-X Premium or LINE-X Xtra. Case and Point (as an example): Ever watch storm chasers on TV? In 2010, they had their Dominator vehicle coated with Rhino. It did not last even one season, the Rhino was damaged and peeled off the vehicle. In 2011, they had it coated with LINE-X Premium. It survived the tornado season with no hail damage (no damage at all) and did not peel off. You can find more info at tornadovideos.net
Old 07-30-2011, 01:36 PM
snrusnak's Avatar
Rep:1385
I personally prefer linex jsut from others I've seen, but I've seen rhino jobs that look identical. I saw two shows on tv: one was mythbusters where they blew up a bomb under the bed of a truck without any liner and it shredded it, then same scenario with rhino, and it merely dented it, the other I don't remember what it was but it was about ballistics and they blew up a bomb in a concrete block room and the room was demolished, then same thing with the block wall coated with rhino and it didn't do any damage. I wouldn't say it's a bad product, and it's much cheaper (in my area anyway). I personally only like the base product, none of the extra stuff.
Sean
Old 07-30-2011, 03:38 PM
Rep:13
The blast mitigation products are not the same as the bedliner products, that applies to both Rhino and LINE-X. LINE-X was the first to invent a blast mitigation elastomer and LINE-X Paxcon (blast mitigation product) has been applied to portions of the U.S. Pentagon (after 9-11) and Federal Building in New York. In addition, LINE-X Paxcon is currently applied to Force Protection's MRAP vehicle using in Iraq and Afghanistan. Also, LINE-X XS-100 (the bedliner product) has been applied to 50,000 bullet proof jacket plates used by the military. Videos of blast mitigation are at Paxcon.com
MRAP vehicle.
Plate that saved soldier's life is presented to Donald Rumsfeld as a plaque. This appeared in Military Times.
Old 08-01-2011, 04:48 PM
DodgeRamJeremy DodgeRamJeremy is offline
Vehicle: 2008 Dodge Ram 1500
Color: Grey
DodgeRamJeremy is on a distinguished road
- Linex
- Rhinolinings -
I wouldn't trust either one - I've got a 5 piece bed liner and I really like it - no risk there!!!
Old 08-01-2011, 05:03 PM
Rep:13
There's a big difference between the LINE-X vid and the Rhino vid.
In the LINE-X vid, something obviously went wrong in the installation process. There's not enough information to know what happened though. Ordinarily, a LINE-X bedliner cannot be peeled out like that. Actually, no spray-on bedliner of any brand should peel out like that with the proper installation. Things can go wrong, like equipment malfuction that sprays at an incorrect chemical ratio.
The Rhino vid is not unusual. Any bedliner company that uses a topcoat that's not durable enough for truck bedliner can have that problem. Rhino will use automotive paint which looks nice, but can wear down fast.
Ahh, Fresh Rhino Lining! thedvsmonkey Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 6 04-15-2011 10:59 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Rhino Lining!!! Valldar Dodge Ram General Discussion 19 04-26-2010 09:20 PM
Rhino Lining 00sport Dodge Ram Detailing and General Maintenance Forum 7 12-12-2009 08:51 PM
Rhino lining matthewyaw Dodge Ram General Discussion 11 10-15-2009 10:39 PM
