Rear end Swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-28-2011, 11:05 PM
jrredd45 jrredd45 is offline
Vehicle: 1999 Dodge Ram 2500
Color: Green
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
jrredd45 is on a distinguished road
Default Rear end Swap
I have two question. First will a rear end from a 2002 Ram 3500 fit into a 1999 ram 2500. Second is what does it take to convert a dual wheel rear end to a single wheel rear end. Thanks.
Old 08-03-2011, 01:23 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top! Drop by the Newbie Checkin and introduce yourself. Hope to see you around!
Old 08-13-2011, 01:19 PM
dyna94 dyna94 is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: 4X4 Sport
dyna94 is on a distinguished road
Converting from dual to single wheel is complicated. They use different length axle tubes and shafts, The dual wheel axle is narrower to keep the tracking right. The 2500 is wider. A single tire 3500 rear end will work, but may possibly need the spring perches moved. I went nuts and put a dana 80 out of a 3500 under my 1500, with a dana 60 out of a 3500 under the front and managed to get it all to work,
Old 08-13-2011, 02:24 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
1. A 1500 axle is not nearly as strong as what's used in the HD trucks. Chances are you'll snap an axle shaft trying to pull with your truck, especially with a cummins.
2. It would take a ton of work to convert a Dana 80 to a single wheel. You could use the dual wheel axle in your truck though. You would still be registered as a 3/4 ton but all you would need would be the wheels and flares, the axle should bolt in
2wd rear axle swap cgoldsberry Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 04-05-2011 12:30 PM
99 2wd rear axle swap cgoldsberry LD RAM - General Discussion 1 04-03-2011 10:36 PM
Rear Interior Light Swap nbh40 Custom Dodge Ram Interior and Exterior Lighting 2 02-27-2011 01:38 AM
Rear end swap 98Rammer 5.2L V8 Specific Topics 4 09-07-2010 01:18 AM
Rear end gear swap?? ScatPackRam LD RAM - General Discussion 6 08-04-2009 07:08 PM
