Old 07-29-2011, 07:39 AM
SmackDownInc SmackDownInc is offline
Vehicle: 2004 dodge ram1500 hemi
Color: flame red
SmackDownInc is on a distinguished road
Exclamation PLEASE HELP STUCK A/C problems 2004 1500 hemi any1????
I have 2004 Ram 1500 hemi that I just purchased.. The A/C does not work The orange light comes on when you press the a/c button...so when under the hood..compressor is not spinning...The 134 level is ok ...I pulled A/c clutch relay and its ok...so while the relay was out I took a wire and jumped the power where the relay go and compressor comes on gets cold and ac works fine.....but when I put the relay back in the compressor shut right off and doesn't come on?? Seems like the compressor is not getting power?? But there is power @ the relay...Relay is not bad cause i swapped them with the other ones and it works fine...ANY IDEAS ON WHAT WRONG??? HELP!! don't know what next to do....
Old 07-30-2011, 06:42 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Check the relays coil side voltage across the coil with a voltmeter with the A/C button turned on, if there is no voltage than it's an issue with the wiring maybe a short or a issues with the A/C control in the dash. It is possible also but doubt it that the low side or high side pressure sensor is dead.
Old 07-30-2011, 11:07 PM
Color: flame red
sorry can you explain i am not following...check@ the fuse box 14 and check the high pressure switch 5volts...
Old 07-31-2011, 12:01 AM
ramvan2500's Avatar
Rep:128
No the relay for the A/C clutch check the voltage at and across the coil of the relay. Relay has four contacts usually in this case it should be 4 because it is a normally open relay so you want to check to see if their is enough voltage being sent to the relays coil to operate the relay.
Old 07-31-2011, 12:51 AM
Color: flame red
yes its @ 14v...i think it was top right and bottom left where the relay goes
Old 07-31-2011, 02:20 PM
ramvan2500's Avatar
Rep:128
Well if their is voltage at the relay coil then the clutch should activate if it's not then the clutch is bad or their is no voltage going to the clutch.
2004 Ram 1500 hemi bad computer cvantuss Electrical 5 12-27-2014 06:04 PM
Thoughts on '03 Ram slt 1500 hemi reg. cab BlueMonkey Dodge Ram General Discussion 2 03-15-2011 05:34 AM
Multiple electrical and Mechanical problems Log - 1998 Ram 1500 gwtaz Electrical 7 03-01-2011 12:19 PM
Oil pressure problems on my 01 1500 Ram 5.2 79JON 5.2L V8 Specific Topics 6 07-28-2010 10:43 AM
Need performance help with 04 Ram 1500 5.7L Hemi 04 hemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 12-30-2008 05:10 PM
